Question about Whirlpool Gold GX2FHDXVY Monochromatic Stainless Steel French Door Bottom Freezer Refrigerator - GX2FHDXVY
Why does the freezer keep filling up with a sheet of ice?
Our Whirlpool upright freezer has a sheet of ice in bottom at drain--why?
Melt it again, and check it runs down the small drain hole, If not, clear the hole with a drinking straw. If it keeps freexing up, you may need an auxiliary heater added to the drain hole.
May 24, 2014 | Freezers
Ice buildup on floor of freezer
Is the fill tube for the ice maker dripping?
Nov 27, 2012 | KitchenAid KBFS25EWMS - Standard-Depth...
Our model 532 keeps over filling the ice maker causing a build up on the back and down all of the drawer. We can turn it off and thaw the entire box and the water keeps filling the tray even though the ice...
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
Aug 10, 2009 | Sub-Zero Freezers
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Freezer Ice Maker Won't stop filling with water
The water solenoid at the back where the water line attaches to the fridge has failed
Jun 29, 2009 | Refrigerators
Water leak in freezer, build up of ice at the base
Remove the ice maker and fill it with water to see if it is leaking. Or check the pipe that fills the ice maker to see if it leaks or is not positioned correctly. Let me know what you find, Thanks, Sea Breeze
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
GE fridge TFX24FHB mfr'd 7/86 - system check display shows "de"
This may or may not be the fix, but I had a problem with my GE Profile TFX24PR sibe-by-side. Water was leaking from the ice maker water fill tube into the back of the freezer, onto the cooling coils. This would cause the freezer to go into extended defrost and the freezer and fridge would warm up. If you see ice inside the freezer, especially around the outside of the ice bin, or odd chunks of ice in the ice bin, turn off the ice maker and/or the source water supply and see if the problem clears up. If the ice buildup is especially heavy, you may need to remove your food, and unplug and manually defrost/thaw the freezer. You may want to remove the cooling coil cover, that is the back wall of the inside of the freezer. Mine had five screws holding a thin sheet of metal, three at the top and two near the bottom. Once this is off you can see the cooling coils. Be careful not to bump or scrape the coils. At this point I found about a quart of ice frozen on top of the coils in one big chunk, stuck to many wires. I carefully broke off what ice I could, and used a hair dryer to melt the rest.
If this is the problem, then you will need to replace the ice maker water fill tube. This is a time consuming job, you have to disassmble the fan compartment on the back wall of the freezer behind the ice maker to get to the fill tube connector. Once you get there it's easy to reach and it just pushes into the connector. In my case, I just reversed the ends and pushed it back in for a snug fit. You may want to consider using a sealer to prevent it from happening again any time soon.
Dec 21, 2008 | GE Refrigerators
Whirlpool Gold GX2FHDXVY Monochromatic Stainless Steel French Door Bottom Freezer Refrigerator - GX2FHDXVY Logo
14 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
