Question about Samsung RS261MDBP Side by Side Refrigerator
The temperature lights keep going up and down and won't stop
Beko sensordry 6kg gets hot on sensordry programs but won,t get hot on timed programs and keeps stopping and starting, any ideas please?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Feb 13, 2015 | Dryers
Temperature Gauge going up and down?
are you sure both of the fans in the front are turning on when hot.
Jun 26, 2014 | 1999 Mercury Grand Marquis
98 legacy instrument panel lights keep going on and off, won't shut off, runs the battery down
There's a pair of connectors, green, under dashboard on left. They should be left unplugged. When they are plugged together, they cause the lights and fans to cycle on and off for diagnostics.
Feb 13, 2013 | 1998 Subaru Legacy
My uniden phone message light won't stop blinking. Have deleted all messages. How do I get the annoying light to stop??
click on menu button
move down to answering set up keep going down to global set up
click menu and down to VMWI press menu
' move down to yes press menu and end
it starts from NBN installation
It will continually reappear so when you get the process correct copy it down
Oct 01, 2017 | Lands Phones
The lights are flashing and won't stop. I tried to unplug and replug same results ...what should I do?
As far as I know, the flashing lights are an indicator that the slow cooker is on, but awaiting instructions. You need to put in a time and then a temperature and then it will stop.
I personally find the power button very disconcerting and keep having to stop myself pressing it once I've programmed the slow cooker, and accidentally switching the thing off.
Nov 05, 2012 | Rival 38601 Smart Pot 6-Quart
My 1988 dodge Dakota 3.9 3 speed automatic 2 w Dr.idles rough and sometimes dies at a stop light and won't restart unless I put the gassed peddle to the floor.when it does finally start I have to keep...
Replace your hose going from intake to brake booster ( vacuum leak) check all other hoses also. Clean the throttle body. And a tune up probably wont hurt either.
Jun 09, 2017 | Cars & Trucks
While running the temp stays normal but if i get stuck in a traffic the temp stars raising really fast
You may have a problem with the fan clutch. Is the check engine light on? If it is, have the codes read to find out what the problem is.
Another possibility is a bad water pump impeller, a worn impeller won't move enough coolant to keep the temperature down.
Aug 13, 2011 | 2003 GMC Envoy
Hi, I have a Bosch undercounter freezer and it won't stop beeping!!! All the lights flash whilst beeping, the lights are under the super freeze button, mute button and the temperatures. If I hold...
The beeping is a signal that the fridge has not got down to, or holding temperature... You may have a thermostat or gas system fault. Check and see that the fridge has actually got cold.
Jul 31, 2011 | 2007 Harley Davidson FLHX Street Glide
At first my 1997 Oldsmobile Cutlass Supreme (only has 59,000 miles) after driving for a while the temperature gauge would start to rise when idling but when I started driving the temperature would go back...
This sounds more like the thermostat is not opening as it should, instead of an ECM problem.
With the indications you state - goes down when heater activated - goes down when moving, that is what I would have checked first, not the cooling fan!
Jun 01, 2011 | 1993 Oldsmobile Cutlass Supreme
My sdmo generator keeps shutting down temperature
http://www.aa1car.com/library/overheat.htm
Troubleshooting advice above link.
Sometimes it is the head gasket, check, it can be, incorrect fuel mixture, far too lean, exhaust should be a light grey color. Check enough oil in sump. ensure free flow of air all around machine.
Mar 28, 2010 | NEC Mitsubishi MGE 1800 Generator-Voltage...
Samsung RS261MDBP Side by Side Refrigerator Logo
23 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
