Question about D Cut TD-080 Wet Tile Saw
Where can I get a replace ent belt - D Cut TD-080 Wet Tile Saw
How much is on my ent card
Call ENT customer service
1.866.840.3792
https://www.visadpsgiftcard.com/Ent/PRC248/CP248-T00-003/docs/contact.htm
Jul 18, 2015 | Cell Phones
How do I enter an MMSI number into my Uniden UM415 It is useless to call Uniden, I have already wasted 3 hours on hold with them.
Hi Peter!
NICE radio Man. You're right, Uniden customer service is horrible.
Ok, here's the deal. You HAVE to get this right the first time, otherwise you pretty much have to send the unit back to Uniden.
Press and hold CALL until the setup menu appears.
Press ENT (1W/25W), that gets you to the user MMSI portion of the program.
NEW should be what you see on the screen.
Press ENT. That'll get you to where you actually get to enter your number.
Using channel up or channel down, set the first number.
ENT
The cursor moves to the next digit.
Repeat until your full MMSI number is entered and displayed on the screen.
IF YOU MAKE AN ERROR, don't panic, press clr/scan and the cursor will move back one spot to the left, erasing the wrong digit.
When the ninth digit is correct, press ENT. The screen will display your MMSI number and ask you to confirm. To save, select yes. To cancel, select no.
Before saving the number, your radio will ask one more time if you wish to confirm and warn you that this is a permanent setting.
Press ENT to confirm, or CLR to start over again.
Hope this helps.
-Steve
Oct 15, 2014 | Boating
My cd/dvd produplicator is now only burning cds and not dvds. I am getting error message that says target drive not ready. Is there a solution or must I replace the target drive altogether?
You can try going to manufacturer's website to see if there is a firmware update. You can try uninstalling a reinstalling the application/drivers for the device as well.
Jun 01, 2014 | Vinpower Digital Computers & Internet
M disc duplicator not recognized by computer
The duplicator has a usb option that needs to be selected via the duplicator controller menu. If your duplicator menu currently reads 1. Copy scroll up using the up arrow key to look for the Usb Mode. You may be prompt to switch to the Usb Mode by pressing Ent. Once you do so the duplicator will reboot and the drive should be available through the (My) Computer screen on your personal computer. If you do not see the Usb Menu option on your duplicator menu you can turn it on by holding down the ESC until you hear a beep. It will display the Adv Setup Menu. Scroll down until you see "Usb Option", press the ENT then scroll down to select the ON position and press ENT. After the Usb Option has been turned on you should press the ESC button twice then scroll up until you see the USB Option, press ENT to view the option then select to turn in ON and press ENT. Feel Free to give us a call if you have further inquiries.
Tech Support - Johnny
Produplicator
866-817-4094
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Nov 29, 2012 | M-Disc Disc Duplicator - 1 Target
Don't know how to set the clock on the 9887 in-dash reviever
From the online manual: http://support.alpine-usa.com/products/documents/OM_CDA-9887.PDF
1: Press and hold Func./Setup for 2 seconds 2: Turn the rotary encoder to select General and then press play/pause/ENT 3: Turn the rotary encoder to select Clock Adjust and then press play/pause/ENT 4: Turn the Rotary Encoder to set year 5: Press play/pause/ENT 6: Repeat steps 4 & % to set month/day/hour and minute
Mar 05, 2011 | Alpine Car Audio & Video
How can i format Y module in the i class datamax printer?
can be done from the Front panel of the printer:
1. press MENU for MENU MODE
2. press FWD key to PRINTER OPTIONS
3. press ENT
4. you will see MODULES, press ENT
5. press FWD to FORMAT MODULES
6. press ENT
7. press FWD to Y MODULE, press ENT
8. press ESC to back out of menu mode. Make sure to press Y when asked to save changes.
Hope that helps !
Apr 11, 2010 | Datamax DMX-I-4212 Label Printer
V ent on inside right of the overn
Hi the part you are refering to is called a wave guide cover. If it has developed a hole it will need to be replaced. this part can be obtained very easily at little cost from Sanyo or any reputable parts supplier
Jan 07, 2010 | Sanyo EM-Z2100GS Microwave Oven
How do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
Jan 01, 2010 | Sony CFD-F10 Radio/Cassette/CD Boombox
Hello- My 332c will not show speed. It worked before.The spinner wheel is not damaged.Speed just flashes 0.00 mph Thanks, Jeff
Try setting up the speed in the overlay data menu again:
1. Press MENU, arrow down to OVERLAY DATA and press ENT
2. Highlight the option for speed (WATER SPEED or GROUND SPEED) and press ENT
3. Highlight the REMOVE button and press ENT
4. Highlight (PRESS ENT TO ADD) and press ENT
5. Arrow down to SONAR DATA and press ENT
6. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box
7. Press EXIT twice
If the speed is still flashing, the data is still invalid. Try resetting the unit completely:
1. Turn unit off
2. Press and hold the PAGES and POWER key until the "DO NOT RELY..." alarm appears
3. Set up the overlay data for speed again: 1. Press MENU, arrow down to OVERLAY DATA and press ENT; 2. Highlight (PRESS ENT TO ADD) and press ENT; 3. Arrow down to SONAR DATA and press ENT; 4. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box; 5. Press EXIT twice
If the speed is still flashing, good chance the speed sensor is bad even though the wheel still spins. Install the latest LMS-332 updates from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/ and set up the overlay data again.
If it turns out that the speed sensor is bad, just use speed from the GPS. This can be set up from the overlay data menu as GROUND SPEED.
(note: the overlay data must be set up for each page individually. So if you set up speed to be displayed on the map screen, it will not also be set up on the sonar page)
Jul 12, 2009 | Lowrance LMS-332C GPS Receiver
I am trying to delete all tracks/routes on CP180 Standard Horizon
reading your owners manual (link provided at below) , i see you can delete / edit points one at a time or a faster way format the C Card.
** formatting the c card instructions >
1.) press MENU , move the shuttle point knob to highlight USER POINTS , and press ENT .
2.) move the shuttle point knob to highlight USER C CARD, and press ENT .
3.) move the shuttle point knob to highlight FORMAT ,
and press ENT .
4.) a popup warning window will pop up to confirm you want to format the user C card .
5.) select YES , and press ENT to confirm , (select NO otherwise) .
NOTE : formatting the user c card erases all files previously saved on the c card .
CP180 users guide
J5
Jan 17, 2009 | Standard Horizon Chart Plotter CP180 GPS...
D Cut TD-080 Wet Tile Saw Logo
67 people viewed this question
Top D Cut Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a D Cut Saw Expert? Answer questions, earn points and help others
