Question about Nintendo Wii Console
How to disassemble a wii rvl-101
I believe one of the kids stuck something into the disc slot on my RVL-101.
5 Suggested Answers
SOURCE: power light went out and won't come on. Hasn't
wii control doesn't turn lights on. if you twist it a bit, the lights go on. must have something a bit los inside. no tec service here
Posted on Sep 13, 2009
  • 839 Answers
SOURCE: My Wii RVL-001 will not
check these things >>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
still the same problem,dont worry check out the following Repair Guide....
click here to download repair guide
Posted on Dec 26, 2010
ccarmac1
  • 199 Answers
SOURCE: Where can I find a user manual for my Wii RVL-001 (USA)?
These work for all type of wii models
http://gamesites.nintendo.com.au/support/Wii_Operations_Manual-SystemSetup_AUS.pdf
Thanks
1RepairStop.com
Posted on Feb 15, 2012
SOURCE: fix a stuck dvd in Wii
There are two ways, 1 stick a sqrewdriver into the slot or talk to nintendo for a repare
Posted on Apr 17, 2012
Just bought this used car and the CD load is very sensitive and will only let me load 1 out of every 6 I try. Is this normal?
Try a dust cleaner but do not shake the can. Just insert the shaft into the removed cd slot and shoot some air in there, then try a cd cleaner disc to clean the disc lens. If the disc player is just shooting them out also try removing and unplugging the radio assembly and shaking the radio, slot facing down maybe something is lodged in the cd input area...kids love that slot...
Mar 08, 2016 | 2007 Acura MDX
2004 Ford F150 rear entertainment system will not eject dvd, will play the dvd and will run when eject button pushed but will not eject the dvd any ideas on how to get the unit to eject the dvd?
The unit is connected by small set of gears that push tray /disc out. As tray comes out it either pushes disc out of slot or pops open door (depending on which style of face you have). If you have kids I would not be surprised if something is caught in between disc and face or jamming edge of door. (know this from own experience). The face of player can usually be carefully popped off by gently prying at corners. If you get face off you may be able to see if something is stuck in unit that does not belong, or see if a piece is broken loose near face. If unit has door that opens you can try using a slim but stiff piece of plastic and keep tension on door with plastic while hitting eject button. On some units there is a small hole on face that is manual release that ejects disc - even if no power. Usually takes a long straight push in hole (straightened paper clip or dental pick) and it manually pushes gear set to go out. So many of these units are different but most do have a manual release. Check owners manual to see if it shows a picture of face and possible release hole. Have had kids fight over changing a disc and pushed in on it while it was ejecting so it stripped gears, and had kid hang on ceiling mount unit that tore screen totally off. I feel your pain....
Jan 21, 2015 | 2004 Ford F150
How to get nexflix on a tv
Getting Netflix on your Wii involves the following steps.
1) Have an active Netflix subscription. (http://www.netflix.com/)
2) Connect your Wii to the internet. (http://www.nintendo.com/consumer/systems/wii/en_na/ht_internet.jsp?menu=connect&submenu=rvl-ht-int-connect-wireless)
3) Download Netflix Instant Streaming from the Wii Shop. (http://www.nintendo.com/consumer/systems/wii/en_na/netflix.jsp?menu=watch&submenu=rvl-ht-chn-netflix-download)
4) Connect to your Netflix account. (http://www.nintendo.com/consumer/systems/wii/en_na/netflix.jsp?menu=watch&submenu=rvl-ht-chn-netflix-download)
Let me know if you need more details on any steps.
Mar 10, 2014 | Nintendo Wii Console
Foreign object i wii
U need to have a Y-shaped screw-driver to open your wii..they are traditionally called tri-wing or Y0. Once you have those, I suggest you take photos as you dissemble the console so that you put it back in the correct (reverse) order that you opened it..
Good Luck
Nov 27, 2013 | Nintendo Wii Console Rvl-101
My wii gamecube cant find the thing to hook my gamecube controller in i put my gamecube game but it just pops out i had another one but that one was tore up so i got a new one but i cant find the thin
if the wii console is laying flat on the table/floor/wherever it is you use it, with the power & reset buttons on the left, open the flap on the left hand side of the console (hinged on the botton). You will reveal 4 slots for plugging in your controller
Jul 09, 2013 | Nintendo Wii Console Rvl-101
Is it beyond repair if plugged in to 220V, but not used?
The higher voltage has burned out the unit. A step down transformer had to be used with your device.
Sep 20, 2017 | Nintendo Wii Console
Cannot hook up Wii rc jacks because dvd is using those ports sujest
Hook them both to a A/V selector switch and then to the TV.
Jan 09, 2013 | Nintendo Wii Console
I cant get tbe wifi to work on the wii
A complete set of instructions are found here: http://www.nintendo.com/consumer/systems/wii/en_na/ht_internet.jsp?menu=connect&submenu=rvl-ht-int-connect-wireless
Is there something else going on?
Jan 01, 2013 | Nintendo Wii Console
Open the lid for game cube controllers
with the power & reset buttons of the console on your left, the lid for game cube controllers should be on the left side of those buttons on the console.. the flap will open from the top, swinging anti-clockwise (so from 12'o clock to 9'o clock)
Dec 11, 2012 | Nintendo Wii Console Rvl-101
How can I play with rvl 101 wii using copy dvds ?
Wii consoles with the RVL-101 drive will not play copied discs at all, no matter what you do.
May 07, 2012 | Nintendo Wii Console Rvl-101
Nintendo Wii Console Logo
342 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
