Question about McCulloch 5pcs General Snap-In Primer Bulb for Stihl / Weed Eater / / Ryobi Echo
Why won't my McColluch weed eater create a vacuum
Changed all the gas lines, cleaned the carb and replaced the diaphragm but weed eater still will not start
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
Posted on Jul 03, 2016
3 Suggested Answers
  • 57 Answers
SOURCE: 14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Posted on Sep 04, 2011
2strokeJim
  • 577 Answers
SOURCE: chainsaw wont throttle up dies out;cleaned out carb. relaced fuel lines .
pull your muffler off and see if it revs up, if it does then your spark aresster screen or muffler is plugged, from carbon or mud dobber hornets
Posted on May 23, 2012
Ridding lawn mower engine runs for a while then stop
Try cleaning the gas cap. It has a vent and if clogged will slowly create a vacuum. Check the air cleaner too.
If not it may be time to clean the carb, YouTube has videos on most carbs.
I have the same problem with my lawn mower and weed eater.
Hope that helps,
David
Aug 28, 2017 | Garden
My Weed Eater FL1500LE gas leaf blower will not run beyond the full choke setting. If I move the lever to half choke the engine will stop. Or if I move the throttle from full throttle to a lower speed...
This is a tell tale sign of a lean fuel mixture. By choking the unit you are manually creating a richer fuel mixture. I would purchase a compression tester from a local parts store and check compression. If that's ok, I'm willing to bet the problem is still carb related. Two stroke carbs are tricky to clean because of high/low ports that are one way and sometimes impossible to clean. Did you remove high and low needles when cleaning carb? Another trick is to mix seafoam with your gas, then mix two cycle oil to proper ratio. Use 2 ounces seafoam to one gallon of gas, then mix two cycle oil to proper mix. Hope this helps! Good luck and happy wrenching!
Sep 22, 2013 | Weed Eater Fl1500 Le Leaf Blowers
PE 550 Poulan weed eater edger. Replaced gas tank that came with new gas lines and gas cap. Runs on full choke but not off of full choke. Also noticed it will run okay with gas cap off. When you...
A bad duckbill vent (the little green thing) inside the fuel cap will cause a vacuum to be created if it is NOT venting to the atmosphere. Odd that all new ones you have used are bad. Maybe try using your old, original fuel cap and the carburetor needs adjusting or at the least; a gaket and diaphragm kit installed. Carb screws are NOT user friendly, thanks to EPA and CARB emissions regulations. You can get onto the heads of them to turn them by tapping a 22 gauge automotive-type plastic wire connector onto the head, and that will give you enough grip to turn them. I would TRY adjusting the carb before getting a kit, but after 2 years or so, a G & D kit is usually needed due to the internals of the carb drying out. If you adjust the carb, this is how the manufacturer says to:
http://www.zamacarb.com/tipspage.html
Sep 06, 2011 | Poulan Pe550 Gas Edger
Only runs good on half choke - will not take gas on open choke.
sounds like a carb problem for sure the diaphragm in the carb has hole in it or the jets are clogged forcing it pull fuel at half choke and not fully open also make sure your gas lines are clear and free of trash but i would put a kit in the carb for sure.hope this helps.
Aug 26, 2011 | Poulan Weed Eater No Pp446t 952802025 31cc...
Pour gas in carb. will run few sec. replaced both gas lines and filter.
You will need to clean the carb or if this unit has a walbro carb buy a rebuild kit and it will work just fine.. Good Luck...
Mar 23, 2011 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weed Eater Problems
If it runs with the choke closed then it's not getting enough gas. Check the gas filter on the end of the gas line in the gas tank. Remove the gas cap and using a piece of wire with a hook on the end, reach in the tank and pull the gas line out through the opening. Check the filter on the end of it. You could also have a burst-ed diaphragm in the carburetor. This sucks the gas from the tank to the carb. If that's the case a new weed eater may be in order unless you can find someone with the parts to repair it. Also check the gas lines for leaks or breaks, 2 of them.
May 17, 2010 | Troy Garden
Craftsman 29cc 4 cycle weed eater. Cranks but will only idle. Seems to bog out. Will only run in full choke at idle. Have changed gas and checked lines for leaks or stoppages. None found. Can not...
remove the sediment bowl on the bottom of the carb,but dont lose the gasket and watch out when the float drops so the needle and spring in the bore dont fall and you lose them,then clean out any dirt in the bowl and in the needle seat andget some carb cleaner and throughly clean out all openings in the carb,its a california carb thats why there are no adjustments
Mar 13, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Mccolluch airstream V back pack blower fuel lines
The short one goes to the primer bulb and the long one, with the filter, goes to the carb.
Jim
Jun 04, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
No Gas to Primer Bulb
It sounds like the carburetor needs cleaned. Take the carb. apart and clean it with carb. cleaner. Use a Den Tech Brush, (used for cleaning teeth), they are perfect for cleaning the small ports in carb. If that still doesn't work, you may need to buy a carb. kit for your weed eater. If so, replace the gaskets and valve needle, and also make sure to replace the small screen. this should all come in the new carb. kit.
May 21, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
McCulloch 5pcs General Snap-In Primer Bulb for Stihl / Weed Eater / / Ryobi Echo Logo
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
