Question about KitchenAid KSM150PS Artisan Series Stand Mixer
110V 6ohz - 220V 50hz
I'm planning to operate a 110V 60 Hz mixer at 220V 50Hz, using a voltage converter for the 110-220V.
Is the speed control of the motor depends on the current frequency, or isn't?
Thanks,
  • ttuanwa Jul 08, 2009
    I live in the USA for 3 Years and i would like to buy the kitchenaid now, after the 3 years i go back to germany an take the kitchenaid with me. there is no warranty after this time, mi question is: Is the speed control of the motor depends on the current frequency 60hz/50hz, or isn't? What kind of motor is build in? Thanks
  • 145 Answers
Kitchenaid mixers are not recommended on the use of a converter as they are not tested under such conditions. Understanding this, using a convertor on your mixer may automatically void the 1 year warranty regardless of age.
There are international Kitchenaid dealers available if you are requiring 110V. You may contacted Kitchenaid Customer Service for more information.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 08, 2009
    Problem Solver:
  • 4 Answers
When traveling to countries with 220 voltage, is there any danger of overheating, or should I use a voltage converter?
You simply can't use any 110V device at 220V, be it a cellphone converter or a food mixer.. Some artifacts have a switch to be used at 110/220 and those, once changed to 220V, can be used.
Jul 01, 2015 | Food Mixers
Want to operate my kenwood mixer from Europe in the us. What do I need to step up 110 to 220 ?
the best would be to just by a us 110v mixer...making 110 to 220 is not as simple as it sounds ,another issue is Europe has220 @ 50hz and us 110 @ 60hz ...
Nov 17, 2013 | Food Mixers
Is it perfectly safe to use a transformer for 120V/60Hz products? Kitchenaid mixers are way cheaper abroad...for a 220V/60Hz using country,this poses a big issue for me...with all the talks about hazards...
Short answer- no problem, but please read on...
First, economics are an issue- there is more than one way to convert VOLTAGE, the ;best' in this case is by using a heavy coil-wound TRANSFORMER (not simply a device being called a transformer or 'converter'; terms often misused) but virtually NO means of converting FREQUENCY (60Hz USA vs 50Hz Eu)
Extended use at wrong frequency has been known, by personal experience, to cause overheat and premature failure of many devices.
Heat is an issue for a hidden reason in the classic models due to their 'mechanical fuse' which is designed to limit serious damage in event of overload (too thick batter mixed for too long)- the device will yield at lighter work-load as the moter heats to greater levels- it is prudent to be always aware of the 'running temperature'.
There are subtle differences in the motor winding design, and you may find difficulty finding repair parts for any relatively minor electrical issues (mechanicals are the same in classic models)
If you have talent for house wiring better to use seperate 220 line, as if for a dryer or electric stove- its more efficient overall.
If you have 60Hz 220 V mixer, (most are 50Hz 'tuned' at 220Volts) a step-up transformer to bring your US 60Hz current UP to 220 volts to suit your mixer will not harm your mixer if it supplys sufficient Amps or Wattage (you likely must convert; Volts multiplied by Amps gives Watts)... But you can easily pay out near half the cost of a mixer to get a quality transformer into your kitchen and still, it remains a weak-link; you can only get quality if you pay for it...
...but the 220V outlet permits use of commercial appliances with all the durability, convenience, and prestiege they afford.
Artesian models with 'soft start' and inverter-technology speed control use much more electronics to feed the motor- they should be supplied as close to true sine-wave power for the same reasons as computer UPS battery back-ups.
In general, and by experience, its best overall to buy the appliance designed for use in the location required. If you feed the appliance the power it was designed to use it has no way of knowing how it got there. The question mark is with the output of the power conversion device.
Oct 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I just bought KitchenAid Artisan Stand Mixer KSM150PS with 110v and 60Hz online and received it today and realised I cannot use it on australia. Can I use transformer which I can get here to convert 110V...
You need a Step Down Voltage Converter (also called a Voltage Transformer)
which steps down 240, 230, 220 volts to 110 volts and
allows you to use 110 volts Devices from USA in 220 v / 230 v / 240 v Countries
Aug 10, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Change Hobart N-50 110 V / 60 Hz to 230 V / 50 Hz
You would need to provide the correct power to match the maching, or replace the rotor, stator, controls to match the higher voltage, and worm gears to correct the speed, from 60 to 50 Hz. Unless you don't mind it running slower. Cheaper to find one that matches your local spec..
Sep 25, 2009 | Hobart N50 Stand Mixer
Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Jul 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen aid mixer, voltage issue
i want to buy a kitchen aid
and i was wondering about the voltage since i'm in Qatar
and i found this answer , Hope its useful
http://www.110220volts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=750-WATT&Category_Code=DownVoltageTransformer
Nov 10, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aid 110v 450watt, I want to convert to 220v
Hi guys,
The only available Kitchen Aid stand mixers on the European markets are the Kitchen Aid Classic and the Kitchen Aid Artisan.
The best way is to contact a Kitchen Aid service center / repair facility in your area.
Here is the European website of Kitchen Aid: http://www.kitchenaid.eu/eu_EU/ka/ka_europe.htm
If you bought a different Kitchen Aid Stand Mixer (like the Professional series) you probably won't find the required parts to convert it to a European model. The only way would be to use a voltage converter.
I hope this helps.
Sep 24, 2008 | Food Mixers
Kitchenaid mixer professional motor
DO NOT DO IT. The Hz will destroy the morotr. The transofrmer only converts the voltage. You are better off buying a 220V version.
Apr 07, 2008 | KitchenAid Food Mixers
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
1,258 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
