Question about Cfm Daikin R410a Split System Air Conditioner
How do you fix a daikin brc1c51/61 with u04 error code?
I have daikin n81 air con, its showing f3 code on the control panel what dose this mean
f3 error is a bad thing, it means excessive compressor temperature in outdoor unit. Overheat condition outdoors. Please find a daikin factory authorized service tech in your area to come check it out. These units are awesome when they work, but when they don\'t, normal HVAC techs tend to not want to touch them. They will try to sell you something else. Or even worse, they want to vacuum and refill them for no obvious reason. A 200 dollar maybe fixit.
The daikin units work more like a tv or a car than the old school air conditioners. They have remote controls and service menus and scan tools and such. A veteran daikin tech can diagnose your system fast and give you a wise estimate of what you need. You may just have a leak, or there might actually be something mechanically wrong outdoors.
I would not push my luck and try to run the unit with this error code. Please don\'t let the magic smoke out of your system.
please mark my answer helpful.daikin ductless
Jan 04, 2015 | Heating & Cooling
How too solve daikin error code c4
c4 error code has nothing to do with outdoor pcb. Use code 41 to check the value of the liquid line sensor and test with mulit meter. Pretty rare fault. Turn the power off for 5
Mins and reboot your system.
Nov 10, 2014 | Cfm Daikin R410a Split System Air...
F8 error split air conditioner
F8 error isn't registered with my Daikin Airconditioner, though E7 showed up as a 'motor over-current' warning.
It might help if you find out the NAME and the MODEL NUMBER for your air conditioner.
Once you know this, then you can search for it like this...
Name - Model - error codes
E.g. 'Daikin Ft18k error codes'
Oct 06, 2014 | Computers & Internet
Fix error code a5
Freeze-up protection. Check that indoor or outdoor heat exchangers are not clogged with dust or dirt. Check filters also. Reset by turning off power to system for 5 minutes and retry. If problem still exists could be a problem with refrigerant levels.
Sep 20, 2013 | Daikin ARC452A9 Replacement wireless...
I keep getting error code u04 when i try to use my machine...what does it mean
Error U04 means the door is open.
Put your knee against the door handle and press it against the handle until you hear a click. The machine should start filling within a minute.
This is a problem I had start occurring about a month after I started using the machine. You will soon do this for every load, a minor annoyance on a cheap machine.
I hope this helps, and remeber leave some testimonial comment. Have a nice day and thank you for using Fixya.
Nov 13, 2011 | Haier HWD1000
How to reset the error code on daikin aircon
more info needed. try fixing the problem then turn unit of at the main power wait for 10 mins then turn on? whats the error code?
Nov 06, 2010 | Cfm Daikin R410a Split System Air...
U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | Cfm Daikin R410a Split System Air...
I have daikin air con brc1c51/61 showing error code J2.
you cannot fix this mate... you will need a fridge mechanic.. try cleaning your filters id say that's your only chance
Nov 11, 2009 | Heating & Cooling
Cfm Daikin R410a Split System Air Conditioner Logo
102 people viewed this question
Top Cfm Heating & Cooling Experts
David Payne
David Payne
Brett Duxbury
Brett Duxbury
Thomas Woodburn
Thomas Woodburn
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
