Question about Amcor Heating & Cooling
Where can i get window kit for this model AF11000E
Does air conditioner AF11000E have to have refriderent added to it if it is functioning good air just isn't cold?
It is possible that the compressor isn't running. Check the temp difference between return and supply. If absolutely no difference chances are the compressor isn't running. If a minimal difference then chances are it's low on refrigerant. You cannot just add gas to those units because they do not have service ports. Repairs out weigh replacement.
Jun 21, 2017 | Heating & Cooling
Where in Southern California can I get it recharged with freon?
Generally portable a/c units are not recharged because they do not contain a service port like a home or auto a/c unit does. At the factory they charge the unit crimp the tube then weld it closed. And no one can service freon unless then can vacuum recover it.
Aug 05, 2015 | Amcor NanoMax 12,000 BTU NanoMist Portable...
Where can I purchase a portable air conditioner window exhaust?
You'll need your model & serial # and contact the manufacturer. Only they will sell the kit
Jun 06, 2015 | Amcor Heating & Cooling
Window kit dimentions i have a window 18 inch wide
The portable AC units generally have a customizable, exhaust hose window, termination kit that comes with the unit.. In other words it can be cut to fit. The one that comes with the unit will fit casement windows, as well as sash windows.
To further assist you, I have included a link to the Owner's/Installation Manual for the model you referenced. You may download and print it if you like.
http://www.air-conditioner-home.com/manuals/ac-12000.pdf
Hope this helped you. Please let me know. Thanks.
Jun 13, 2011 | NewAir AC-12000E Portable Air Conditioner
Where can i find mounting brackets for my kdc-mp332? i have a older truck and i havent been able to find one for sale on the web
are you talking about a dash kit to mount radio into the dash of your truck
or the metal cage that goes around the radio to mount into a dash kit ...
what model truck do you have i can check my supplier for kits for truck
http://www.tintingbyfredjohnson.com you can email me from my online store that sales car audio window tint air suspension and lowering kits
Dec 23, 2010 | Kenwood KDC-MP332 CD Player
My adjusting block is worn, can I purchase a new one?
It depends on which saw you have. Are you aware they are no longer in production? Eventually a replacement part will not be available.
You do not give us the model number of your saw to verify this will fit.
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
• Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
• Click the "YourModelNumber" - Remington Electric Chain Saw "View Model" link.
• Click "View Owners Manual" or "View Illustrated Parts Diagram" link.
• Type "YourPartNumber" into the "Search for your parts by Part #:" window, then click search.
A tension repair kit is available here:
MasterParts.com
http://www.masterparts.net/Merchant2/merchant.mvc?Screen=PROD&Store_Code=MPD&Product_Code=108640-MD
Part number 108640-MD; DESA SPECIALTY PARTS: KIT, ADJUSTMENT SCREW FOR SPROCKET COVER (REM-18); $5.95.
Kit fits the following covers: 108640-01, 116675-01 and 108641-02 (note: for the 108641-02 the screw will adjust from the front with a screw driver, not with a thumb screw at the back) KIT INCLUDES: screw, clip & adjustment block. If not available here please reply (below) with that information. TIA
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
May 01, 2010 | Remington Electric Chain Saw
I think I am missing a part for my Remington lnt-2 12" chainsaw
You do not give us a model number to verify this will work on your saw.
Remington.com
MasterParts.com
Lou
Apr 21, 2010 | Remington Electric Chain Saw
Need a new tensioning screw for a model 111174-01 Rem. chainsaw
Your model number is a dead end. use 107625 (it includes yours). I think this is what you need.
Remington.com
MasterParts.com
Lou
Thank You for using FixYa.
Apr 19, 2010 | Remington 16" Electric Chain Saw
Amcor af11000e air conditioner. The fan runs, but doesn't cool. The compressor tries to turn on but just clicks back off at regular intervals. The compressor light is on.
it is either the capacitor or it has no freon you can replace cap but not add freon not worth it. you should return it if you can
Aug 05, 2009 | Amcor AL10000E Air Conditioner
Heating & Cooling Logo
16 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
