Question about Husqvarna 28cc Hand Held Blower HVH 125B
Brand New Husq 125B runs then dies...
My brand new Husqvarna 125B blower, right out of box, first time using, added correct oil/gas mix, had no trouble starting, warmed it up, but while using for 1 minute on high it starts to slow... slow... slow, then stalls. Restarts quick then same thing. Whats up ?
rwvanlue
  • 486 Answers
SOURCE: my leaf blower will start but wont run
fuel system needs cleaned
check fuel lines
filter
remove carburetor for replacing diaphragms/gaskets
Posted on Nov 08, 2009
  • 430 Answers
SOURCE: I have a Husqvarna 125B handheld blower, will not stay running
probable clogged screen in carb. rebuild carb with a kit. also check fuel lines and fuel filter
Posted on Nov 23, 2009
SOURCE: I have a Husqvarna 125B leaf blower with less than
run for 10-20sec. cut off
Posted on Nov 06, 2010
daneinwv
  • 124 Answers
SOURCE: husky 125B blower, new right
My name is Dane and I am going to assist you in solving your problem.
You will need to adjust the high speed setting on your Carburetor jet. Turning the screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the Carburetor, however, yes you do need a special tool that is very hard to get your hands on, in order to adjust the jet screws. They don't make many engines with plain screw heads anymore. The newer Carburetors are factory set lean so they can pass emission standards. Since you just bought yours, a local husky dealer should adjust the mixture for free. I hope I've helped. If you found this reply useful, please leave me some THUMBS UP, if you feel I
Posted on Dec 09, 2010
  • 130 Answers
SOURCE: I have an Husqvarna 125B
The carburetor has an inlet needle that prevents fuel flow when the unit is not in use. There is a certain amount of "pressure" in the fuel system since the fuel cap vents in but is not designed to vent out. The inlet needle will hold off a certain amount of fuel pressure but if it becomes greater than the spring tension that holds it against the seat, it will "pop off" and allow fuel to flow into the carburetor. By the same token there is a diaphragm that opens the inlet needle when the unit is being started and while it is running. The diaphragm works off of atmospheric pressure outside the carburetor to open the needle and allow fuel flow. If the diaphragm becomes "hard" and does not flex back and allow the needle to close, it will also allow fuel to flow and cause a flooding condition. Hope this helps to send you in the right direction.
Posted on Feb 16, 2011
Husqvarna 125b won't prime and run unless upside down. If turned right side up it dies. If I prime it when it's right side up it blows bubbles in the tank.
Try a new gas cap. There needs to be air behind the liquid in a vacuum (think plumbing) or it does not flow. Make sure you've replaced all the cracked lines. Allowing air into the vacuum will also stop the flow. It's one of these.
Sep 13, 2014 | Husqvarna 125B 28CC Gas Leaf Blower...
New Husqvarna 125B blower runs fine then stalls
Is the gas fresh or old that you used. Since this brand new, it's under warranty. If you've had it for a few days, return to the store from which purchased it. It should run right out of the box without having to work on it.
May 16, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
Required fuel oil mix
Two-stroke oil with a 50:1 (Gas:Oil) mix ratio is required for the Husqvarna 125B leaf blower. Using the wrong oil or improper mixture ratio can drastically affect the performance of the leaf blower.
Nov 02, 2012 | Husqvarna Hand Held Blower 125 B Grass...
Brand new and staling
Is the choke leaver in the off position when warmed up? Have you used correct fuel/oil mix?
Jun 26, 2012 | Husqvarna Forest & Garden 125c 17"...
Whats the best premix gas to use on a Husquarna 125B hand held Blower
The best mix to use is what's recommended in the manual but in most cases blowers use a 50:1 mix. The difference from 40:1 to 50:1 is negligible but you have to use what the motor is built for. Too much oil causes a loss of power because the gas won't burn efficiently. Too little oil and you risk damaging your piston or cylinder.
Feb 22, 2012 | Husqvarna Hand Held Blower 125 B Grass...
Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
Aug 02, 2011 | Husqvarna Hand Held Blower 125 B Grass...
Husqvarna 350 has spark and fuel wont start just quit running while in use
1- Is the mix (gas & oil) right? If its 2-cycle,check the manual.
2- Is the choke set?
hope this helps
Jan 06, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I have a Hasqvarna 150BT blower that started to make a knocking noise at full power and has lost some power. Seems to start ok. Loss of power / rpm and knock are only ploblem?
I had the same issue with a Husqvarna 150 BT blower. Brand new ran through 2 tanks of gas and need to buy more gas , mixed 50 to 1 ratio 87 octane on new gas which was the same as what i was running and it started pinging and running like **** then stalled and would not start. took the plug out and it was fouled. cleaned the plug got it running again but still not good. This model comes with a NGK CMS7H plug which i replaced with a champion RZ7C and new gas 93 octane and lawnboy oil mixed 50 to 1 ration and now its running like a champ. I've had bad experiences with NGK spark plugs in the past and thought this may resolve the issue and it did. Hope this is helpful to anyone out there having the same issues. Also used some fuel stabilizer in the fuel mix, I hear this helps with the ethanol problem in the fall/winter gas.
May 13, 2010 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Husqvarna 28cc Hand Held Blower HVH 125B Logo
170 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
