Question about Clarion DB185MP Car CD/ MP3 Player
HOW DO I SWITCH TO THE RADIO - Clarion DB185MP Car CD/ MP3 Player
1998 ford explorer radio does'nt work switch on sterrein wheel broke.how to fix it ?no power to the radio
You can't turn it on by the switch on the radio ? Nothing showing on the radio display ? If not check these fuses
Blown central junction box (CJB) Fuse 1 (7.5A), Fuse 20 (7.5A), Fuse 28 (7.5A), and Fuse 29 (25A) . The switch on the steering wheel should not stop the radio from being turned on at the radio !
    Even
Mar 20, 2015 | 1998 Ford Explorer
Which wires go to what in the radio
ITEM - WIRE COLOR - POLARITY - WIRE LOCATION
12V - red - POSITIVE - ignition harness
STARTER - white - POSITIVE - ignition harness
IGNITION - red - POSITIVE - ignition harness
ACCESSORY - red - POSITIVE - ignition harness
SECOND ACCESSORY - yellow - POSITIVE - ignition harness
BRAKE WIRE - white - POSITIVE - brake pedal switch
RADIO 12V - red - POSITIVE - radio
RADIO GROUND - black - NEGATIVE - radio
RADIO SWITCH - yellow - POSITIVE - radio
RADIO ILLUMINATE - pink - POSITIVE - radio
POWER ANTENNA - gray/orange - POSITIVE - radio
LF SPEAKER - white - brown - radio
RF SPEAKER - green - orange - radio
LR SPEAKER - yellow - black - radio
RR SPEAKER - orange - blue - radio
Jul 02, 2011 | Hyundai Motor 2003 Elantra
I have a 1991 Fleetwood Cadilac. The radio has a push botton On-OFF switch. The switch started to malfunction some time Finally it would not turn radio on at all. Can this switch be repaired as the...
Yes, that is a great radio, most of them have AM Stereo and an equalizer, so it is worth fixing. You can get a 'junker' radio and just have the Power switch replaced in it. If you live close to me, I'd even do it for you! Good luck. You need to make friends with a local ham radio operator, as he/she could help you out! Let me know how it works out for you.
Mar 03, 2011 | Jensen MR-400 AM/FM/TV Radio
No radio signalcar on car radio player
there is a micro switch inside the player than turns off the radio when the cassette is being played, this switch fails and locks out the radio, this defective switch causes the radio to not switch switch back on when the cassette is removed, u do not mention the make model or year so that is about as much as i can give you right now, but in most cases if this is an older car it is best to try find another used radio on EBAY, if it is an aftermarket unit just replace it, the repair cost in most can exceed what the cost of a replacement is.
Oct 24, 2009 | Car Audio & Video
How do I turn the radio on the wireless card
When your computer is switched on, the WiFi radio is almost always transmitting or receiving signals. In certain situations, as in an airplane, signals from the radio may cause interference. Use the following methods if you need to disable the radio and use your notebook without emitting radio signals.
Use the Optional Computer Radio On or Off Switch
If your computer has an external switch installed, use it to switch the WiFi radio on or off. See the computer manufacturer for more information about this switch. If you have Intel® PROSet/Wireless installed, the current state of the radio displays in the Intel PROSet/Wireless main window and on the Taskbar.
Use Intel PROSet/Wireless to Switch the WiFi Radio On or Off
From Intel PROSet/Wireless, the WiFi radio can be switched on or off. The status icon on Intel PROSet/Wireless displays the current state of the radio.
To start Intel® PROSet/Wireless, use one of the following methods:
  • Click Start > Programs > Intel PROSet Wireless > WiFi Connection Utility.
  • Right-click the Taskbar icon prosettaskbaricon1.jpg located in the lower right corner of your Windows* Desktop to open the Taskbar menu. Click Configure WiFi.
  • Double-click the Taskbar icon to open Intel PROSet/Wireless.
Switch the WiFi Radio On or Off from the Taskbar Icon
To switch the WiFi radio on or off, click the Taskbar icon image1_ipswtaskbaricon.jpg and select WiFi On or WiFi Off.
How to use the Device Manager to Disable the WiFi Radio
The WiFi radio can be disabled (made non-functional) from the Windows* Device Manager.
Note: If you disabled the WiFi radio from Windows*, then you must use Windows to turn the radio on. You cannot use a hardware switch or Intel PROSet/Wireless to enable the radio again.
Windows* XP
  1. From your desktop, right-click My Computer.
  2. Click Properties.
  3. Click Hardware.
  4. Click Device Manager.
  5. Double-click Network adapters and expand the selection by clicking the Plus symbol.
  6. Right-click the installed WiFi adapter.
  7. Choose Disable from the menu.
  8. Click OK.
Windows Vista*
  1. Use Control Panel > Mobile PC > Adjust commonly used mobility settings (if you use Classic View, select Control Panel > Power Options.
  2. Click Turn Wireless Off .
Hope this helps !
Jul 03, 2009 | Acer Aspire 3000 Notebook
Wireless adapter radio
Windows* XP
  3. Click Hardware.
  8. Click OK.
Windows Vista*
Nov 05, 2008 | Acer Aspire 3000 Notebook
Radio Wiring Help
Never heard of that, Just saw a switch like that on a Honda accord. Raised it and lower whenever you wanted. If you got an aftermarket radio, connect a switch between the Antenna power wire and the receiver antenna power of the radio, you can get the switch at radio shack. A 3-way jump switch should be your option.
Aug 06, 2008 | 1995 Toyota Camry
Waking up to the Radio
On the side of the clock radio (I think the left), switch the switch that says CD/Radio to Radio and it will wake up to the radio.
Nov 23, 2007 | Emerson CKD9901 Clock Radio
Clarion DB185MP Car CD/ MP3 Player Logo
13 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
