Question about Oakley - Wisdom
The right hand arm has broken off at the hinge point, can this be repaired ?
    Problem Solver:
  • 14 Answers
Yes it might be able too.it also depends on how bad. go to your local snowboard shop
Posted on Jul 10, 2009
Broken hinge
take the old hinge to your local repair shop and you will get a second hand one for a song it easy to put on
Jan 28, 2014 | Siemens WFXD8400UC Front Load Washer
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Nov 04, 2013 | Kitchen Ranges
CAN I REPLACE A BROKEN HINGE TO A HP 2140
Yes you can.
These WEB sites shows how.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br... Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Dec 07, 2012 | HP Mini 2140 Notebook
The right and left - hand hinges of my Asus notebook got damaged. Where can I have them repaired? Only those parts got broken a little bit, just like semi-fructures. Thanks.
Hi, Just go to ur nearest computer shop and ask them to replace that hinge! the hinge becoming stuck and only solution would be to replace it! The crack can be repaired and repainted if there is no available parts in the market. Ur concern should be the hinges, replace it before it breaks the whole hinge holder!
Jun 14, 2011 | ASUS Computers & Internet
My canon ImageClass MF6550 only make blank copies and prints no error message is detected
I have copy and pasted this solution from another question I answered from a person with the same issue. Several people have reposnded that this solution helped them very much.
This is either your toner cartridge or more likely the plastic arm that opens the laser shutter is broken. When you insert a toner and close the access door, there is a plastic arm that opens the laser shutter. If this shutter does not open it blocks the laser and results in blank copies. If the arm is broken you CAN open the laser shutter manually and block it open. What you need to do it open the cartridge access door, remove the cartridge and look for a 1/2 inch wide slot running from left to right in the metal frame that is in the back upper section where the cartridge goes. The plastic arm that operates the black plastic shutter is on the right side. If broken you can manually lift up the shutter and "block" it open using something like a folded up scrap of paper. I know it sounds strange but I have used this repair on several of my customers machines and they have all worked fine since. If you can not find or effect the repair yourself at least you will know where to point the service person when they come out to look at it.
Good Luck and Thank You for using Fixya.
Apr 13, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
Can not get saddle bag open the lach is messed up and won't open
The solution to this problem, unfortunately, will involve the destruction of two hinge pins; since the hinge is sold only as an assembly, the entire hinge will have to be replaced. I'm sorry about that, but I thought you ought to know that before you start the repair.
Look at each end of the hinge (on the outside of the bag); you will notice a hole and (it may take a flashlight to see it) the end of a hinge pin within. Those hinge pins will have to be driven toward the center of the hinge until the hinge halves separate; that's much less than an inch, but is SEEMS more like 30 feet. Use a nail set that fits loosely in the hole, or a hardened nail about the same size with the tip ground flat.
Once the hinge halves separate, you'll find that you can lift that side of the saddlebag cover only a very short distance; the nylon fabric hinge cover on the inside keeps the cover from opening more than a VERY few inches. The hinge cover is secured by 3mm hex bolts; use a 3mm allen wrench to remove the bolts and the saddlebag top should swing open far enough for you to get your hand inside.
Take a flashlight and examine high on the opposite side of the saddlebag, inside the bag just underneath the cover; there are two catches covered by a broad plastic shield. Use your 3mm allen to remove the plastic shield, then use a small socket to remove the bolts holding the catches to the bottom part of the saddlebag. You can now lift the top of the saddlebag off and reveal the bottom of the catch.
The cover of the catch is secured by 1/4-turn fasteners, you'll see the phillips-head slots. Turn the screwheads until all fasteners are obviously loose; the cover can then be removed. There is a bent catch actuator arm beneath; push the top (free end, well, actually MIDDLE) of the arm toward the outside of the saddlebag cover, and the catches you removed from the saddlebag can be freed and remounted on the saddlebag.
You'll see the bottom of the release button through the catch actuator assembly; push it out, back to its' normal position. You're likely to find one of two things wrong: the actuator arm (4XY-2841A-00-00) is bent or broken, or the lock assembly (4XY-W2843-00-00) has a bent or broken actuator tab or lever. A bolt may also be missing from either the actuator arm or lock assemblies; that would typically cause misalignment or binding.
Replace the hinge, reassemble the saddlebag top with the appropriate repair parts, mount and take a nice, long ride to relieve the frustration.
Mar 17, 2010 | 2006 Yamaha Royal Star Venture
The right hand hinge on a compaq nc4000 is broken. how do i replace it?
Requires disassembly of the laptop and screen. If you need it repaired and can't get it repaired locally, I can help.
Jan 05, 2010 | HP Compaq Business Notebook nc4000
The right hinge on my screen is broken. Can it be
Here's a link to hinge repair procedures...
http://www.laptopka.com/2007/08/01/replacing-satellite-a45-broken-hinges/
It also has a link to search for the replacement part you may need.
Jan 01, 2010 | Toshiba Satellite A45-S250 Notebook
HP C500 Presario Hinge
no ....before you lay your hand call hp and tell them my left hinge is broken and if there is a recall on your notebook it will be fixed free by hp
Feb 15, 2009 | HP Compaq Presario C500t Notebook
Sony vaio vgn fw21l,loose hinge
My hinge broke on my Sony VAIO and the solution I found was to purchase the Service Manual for the laptop then take the laptop apart and find out which part number the hinge was. Then purchase the hinge directly from USA, which took 1 week to come through and mended the laptop myself.
Sony are doing this to everyone who has problems with the hinges of the laptops as they state the guarantee covers everything EXCEPT the hinges. If you can get proof from a pc repair shop that the hinges are a design flaw then Sony will repair it free of charge, but they will still request a Diagnostic fee which will be refunded if the problem you described turns out to be true.
Jan 02, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Oakley - Wisdom  Logo
399 people viewed this question
Top Oakley Winter Sports Experts
Arnie Burke
Arnie Burke
Marvin
Marvin
vtrktrmn
Are you an Oakley Winter Sport Expert? Answer questions, earn points and help others
