Question about Music
How to factory reset a yamaha p105 - Music
I have a Yamaha dtexpress. Very old, but works great. Except the snare sound. It is stuck on bongos. Is there a factory reset for the dtxpress?
1) Press the [UTIL] button.
2) Press the [PAGE DOWN] button until the 'Factory Set' screen appears. The message 'Factory Set' will begin flashing on the LCD.
3) Press the [SAVE/ENT] button. The LCD will display the message prompt, 'All data will be lost, Are You Sure?'.
4) Press the [SAVE/ENT] button again to complete the Factory Reset procedure.
Dec 31, 2017 | Yamaha Music
My Yamaha PSR S500 keys are playing wrong notes
Is there a pattern to the wrong notes ( eg all up a semitone ? )
If so you could have altered the tuning.
Try a master reset:
Hold down top key whilst turning on. This will reset to factory setup.
See attached for individual reset procedures:
Dec 05, 2015 | Yamaha Music
How to factory reset my Yamaha PSR S500
According to the manufacturer, the reset procedure is documented here and on page 42 of the instruction manual:
http://faq.yamaha.com/us/en/article/musical-instruments/keyboards/digitalkeyboards/portable_keyboards/psr500/656/2085/psr500-psr500m_factory_reset_procedure
  • Turn OFF the Power.
  • Press and hold the 'Custom' [RECORD/END] and [CLEAR] buttons.
  • Turn ON the power. The screen will display 'clr'.
  • Release the 'Custom' [RECORD/END] and [CLEAR] buttons.
  • Dec 05, 2015 | Yamaha Music
    How do i reset the keyboard to factory settings? It sounds really weird right now
    You can normally reset Yamaha keyboards by holding down the highest note while turning on. If you want to do a full factory reset see below - remember this may delete all songs etc you have saved to the keyboard memory.
    decdbba2-706f-4a8a-afd1-ac3a6264c7f4.jpg dcd670d5-cf98-45e6-87a4-0591820eb4ef.jpg 2c144414-99a6-4025-960d-eaef496036a3.jpg
    Jul 20, 2014 | Yamaha DGX-230 Portable Grand Piano
    Factory reset yamaha p85
    1) Try a partial reset by holding down the last white key while turning the unit ON.
    2) If you haven't recorded any performance(s), for a full reset, hold down on the last white key AND THE lst three black keys while turning the unit ON.
    Dec 14, 2013 | Yamaha P85 88Key Portable Digital Piano
    Factory reset for the yamaha aw4416 workstation
    The original factory settings of the AW4416 can be restored by recalling Scene Memory '00'.
    1) Press the [SCENE] button in the 'AUTOMATION' section.
    2) Press the [F1] button to display the 'Scene Mem' page.
    3) Turn the (DATA/JOG) dial to select '00.Initial Data' on the screen.
    4) Press the yellow [ENTER] button.
    Reference: Operation Guide, p. 203
    Sep 09, 2012 | Yamaha Aw4416 Aw 4416 Workstation
    Yamaha MM6 Factory reset?
    My Yamaha MM6 Synth is showing blank (white) screen when switched on. Keyboard sounds and banks are working. Everything looks nice but not showing any details on screen. Any help.....
    May 20, 2012 | Yamaha MM6 61 Key Synthesizer
    My YAMAHA PSR-S900 is full of viruses! how can i proceed to clean it?
    The computer processor in these is NOT subject to the viruses like PC's are.
    Do a factory reset on the keyboard to restore factory settings.
    Dec 27, 2010 | Yamaha PSR-S500 Digital Keyboard
    I need to reset ( Factory settings) my Yamaha DTEXPRESS IV drum kit. Erase all input and bring it back to factory setting. Is that possible? Many thanks P.
    Here is a link to the manual if you don't have one:http://www.dtxperience.com/documents/Manuals/DTXPRESS_IV/DTXPRESS_IV_Owners_Manual.pdf The procedure is on page 35.
    Nov 15, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
    The Sustain pedal does not work.
    When push comes to shove, a factory reset never hurts.
    Assuming you'd like to proceed with a factory reset, follow these steps:
    This procedure makes it possible to restore the S08 to the original factory-installed Internal Voices, Multis and System settings.
    WARNING: The current settings for all Multis and User Voices will be deleted. If the current settings and data are not expendable, create a backup before executing the Factory Reset.
    1) Press the [UTILITY] button.
    2) Press the [JOB] button. The 'FactorySet' screen will be displayed.
    3) Press the [ENTER] button. The 'Sure?' message prompt will appear.
    4) Press the [INC/YES] button to execute the Factory Reset. The 'Completed!' message will be displayed to indicate the procedure has been successfully executed.
    5) Press the [EXIT] button to return to the Utility Mode.
    Oct 14, 2017 | Yamaha Full-Size Keyboard
    Music Logo
    184 people viewed this question
    Top Music Experts
    Michial Gueffroy
    Are you a Music Expert? Answer questions, earn points and help others
