Vizio model VW37l hdtv20a will not power on the
Vizio model VW37l hdtv20a will not power on the vizio stays amber have removed the back panel and inspected the power supply as well as main board no obvious problems how ever found cap c1 on the inverter board blown could this be the cause of my problem
    Champion:
    Habit-Forming:
  • 239 Answers
Could well be
Posted on Jun 30, 2014
  • 718 Answers
SOURCE: Vizio L37hdtv10a fails to fully turn on
You will have to isolate the main board and Inverters.
Unplug the inverters and turn on the set.
If it "turns on" then try re-connecting each inverter seperately to see if only one is causing the problem.
Posted on Mar 07, 2009
ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
SOURCE: My VP504fhdtv10a vizio plasma TV when connect
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Posted on Feb 07, 2011
ladywinn
  • 5138 Answers
SOURCE: vizio vw42lfhdtv10a has no picture,
You need to replace the Main unit board.
Look on Shopjimmy.com
Posted on Jul 02, 2011
budmrtn
  • 11361 Answers
SOURCE: i have a vizio vw32l
If you lost the control when trying to use the switches on the TV, it means that the Main board is not functioning, this can be due to bad processor, bad unsteady DC. The main board send the ON signals to the Power supply and the backlights inverter board.
You should inspect the power supply module first since unstable DC can cause a lot of problem, if the voltages and components checked out OK , then you may ahve to change the main board. It will require in-depth troubleshooting to really narrow down the cause of the problem.
Please read my guide first to see if you will want to DIY repair or not.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Aug 06, 2011
Vizio tv no sound or picture?
Could be the capacitors going or have gone out. This is a common problem with Vizio TVs...including mine recently. Check out YouTube for tutorials on how to change the capacitors.
May 09, 2016 | Vizio Televison & Video
My vizio p50 hdtv20a have sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Nov 21, 2015 | Vizio Televison & Video
How to fix my vizio tv that has power but no picture
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 09, 2015 | Vizio Televison & Video
I have a vizio vw37l hdtv20a. A few years ago shortly after getting it the TV made a sound almost like something popping, then just turned off. When i plug it in no lights come on or anything. It's been a...
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 01, 2017 | Vizio VW37L 37 in. LCD HDTV
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
Vizio VW37L no power
Check for bad capacitors in power supply, check voltages coming out of the power supply, if voltages are good, bad main board.. Vizio's are notorious for bad main boards.
Nov 23, 2011 | Vizio VW37L 37 in. LCD HDTV
WHAT IS THE REMOTE CODE FOR A 42' VIZIO MODEL NUMBER VW37L HDTV20A
0116
0117
1126
0113
0115
0114
Please try those codes. These are from a Vizio manual.
Sep 06, 2011 | Vizio 42 in. LCD TV
I have a vizio vw32l hdtv20a it dont turn on now the vizio light is amber when plugged in turns white when you press the power button but the screen stays black as it does when its off NOT black as when...
Aug 06, 2011 | Televison & Video
My VP504fhdtv10a vizio plasma TV when connect power cord the Vizio in front light up yellow/amber but will not turn on. I have replace Logic Control D Board still have same problem. I do research online...
Nov 07, 2010 | Vizio VP504F 50 in. Plasma HDTV
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
