Question about Garmin GPSMAP 60CSx GPS Receiver
Garmin Position Format / Map Datum for Egypt
I owne a Garmin GPSmap 60Csx. I have imported it from Germany with maps of Egypt installed. I have on offset to the East of abot 5 km. My initial thought is that I am using the wrong Position format and Map Datum for Egypt. Can anybody tell me what the right settings for Egypt are?
    Problem Solver:
  • 16 Answers
Egypt Maps for all Garmin GPS
www.a100100.com
Posted on Jan 24, 2010
How and what steps to install a more detailed map of USA to Garmin GPS Map60CSx?
To get more detailed mapping for 60CSx the easiest way is just to purchase them on a pre-loaded microSD card. You can also buy mapping on DVD but this requires you to load your own SD and is a little bit more work, but this would give you the ability to view them on your PC and create custom routes. All these items can be obtained from www.gpscity.com or www.gpscity.ca.
Hope this helps!
Mar 28, 2011 | Garmin GPSMAP 60CSx GPS Receiver
Using dnr garmin or map source how do I transfer from excel
I've just had to do this. Somewhat annoying and I'm sure there must be a quicker way. Let me know if you find one. <br /><br />Firstly you need ArcGIS or something that can create .shp files. Load the Excel file into this. In Arc you need to right click the table and display the x y data (just to make sure it's all okay). Then save as a layer. Then export as an .shp file. <br /><br />You can the open the.shp in DNRGarmin and upload to your GPS..,<br /> <!-- from fixya rte -->
Jan 13, 2010 | Garmin GPSMAP 60CSx GPS Receiver
How to Transfer Maps to GPSmap 60csx
You have use the unlock wizard to install the key that is provided with the software. When I bought my Mapsource CitySelect, it came with two keys. The way Garmin does it is, you can install the software as many times as you want on as many machines as you want, but can transfer the maps, data, etc ONLY to unlocked devices. Last I checked Garmin wanted $75 for additional unlocks. Some data is not locked, like Topo maps and some tide points since this data is obtained (by Garmin) from the gov't, which is free for us (wel, minus taxes we pay). Contact Garmin support, they are very attentive.
May 29, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Garmin Gps60csx is not position me correctly, always 20m out.
Try turning off the Lock on Road option, on Map Setup page, General Tab.
Mar 03, 2009 | Garmin GPSMAP 60CSx GPS Receiver
I have cganged settings on my GPSmap 60CS and it now display only waypoints and not complete tracks. Can anybody out there advise?
On the Map page press Menu. From the options shown choose Setup Map. Go to Track tab and make sure Saved Traks is not set to OFF.
Jan 12, 2009 | Garmin GPSMAP 60CSx GPS Receiver
GPS position is offset from map location
This could be because your datum and your posistion format. Under your menu go to setup, then units and make sure you have the correct info set in there for your area. NAD27 Canada would be the one you are looking for. Give that a try and see if it works. If it is still off, consult the manuals that came with your topo and see if it says what datum it uses.
Nov 15, 2008 | Garmin 010-C0495-00 TOPO Canada - Manitoba...
My map on my garmine 60csx doesnt line up with the actual locations
The most common cause of consistent offset is DATUM selection. The DATUM was likely set to WGS84 at the time of recording then viewed later in NAD27, or vice versa.
Geocaching.com uses WGS84. The USGS generally uses NAD27
Also see this Garmin page. The DATUM is set under Settings | System if I recall correctly.
Oct 22, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Garmin GPSMAP 60CSx
I think all the Garmins allow to do is generate a waypoint list on your PC and upload THAT to the GPS, according to what Garmin told me about my Streetpilot C340. You also need Mapsource on the PC.
Mar 31, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Have you highlighted the section with the map select tool, then hit the Transfer to GPS button? If you do, what happens then? Does it freeze?
If you are able to send routes and waypoints to the unit, you should be able to send selected unlocked maps as well.
Dec 31, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Not acquiring satellites
Go to the Garmin Website and see if there is a Software update Available Hope this helps ttech
Jul 24, 2007 | Garmin GPSMAP 60 GPS Receiver
Garmin GPSMAP 60CSx GPS Receiver Logo
459 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
