Question about Black & Decker Quick N Easy X400 Iron
Where can I find this iron? Quick'N Easy,#480 in Bridgeport, Ct?
Adding water to my iron?
You tip it up and pour water slowly in the little funnel at the tip end.
Feb 29, 2016 | Black & Decker Quick N Easy X470 Iron
How do you put water in it?
The filler opening is at the very front. Set the iron on its heel, press the button above the filler opening, and pour in distilled water until the iron is full
Jan 15, 2013 | Black & Decker Quick N Easy S350 Iron
Handle loose
Just look around for a loose screws, and tighten the screws. Should be a quick easy fix.
Nov 13, 2012 | Tefal Pro Express GV 8120 Iron
My iron won't heat. it has electricity but won't heat
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101
Jun 25, 2011 | Rowenta DE-480 Iron
My iron won't turn on and if it does turn on it will shut off within seconds. Can you help with this issue? Black and Decker x420
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jan 21, 2010 | Black & Decker Quick N Easy X420 Iron
My DE-480 iron won't heat
check stat,and element,element could be us
Nov 15, 2009 | Rowenta DE-480 Iron
How to open to get water inside
No need to open iron! You just unplug the iron. Hold the iron upright. Using a clean cup, pour water into the "open" WATER FILL HOLES just above or in front of the Temp. Select Dial. Watch the water window on the left. When water level reaches MAX, you are filled. Plug in and use. Refill as needed. Ref. - Page 8 in the instruction pamphlet.
Oct 18, 2009 | Black & Decker Quick N Easy X420 Iron
How to clean inside of Iron?
Unplug the iron! Allow iron to COOL completely!!! Wipe soleplate with damp soft cloth or damp soft sponge. NEVER use abrasives, cleansers, scouring pads that will scratch iron and cause discolorations. The iron has an Auto Clean Steam Valve feature that will prevent most mineral and lint build up everytime you turn the Temp. Select Dial to "0" after use. (Ref. - page 11 of the instruction pamphlet). If you have a really bad hard-water build up problem, use a commercial Steam Iron Cleaner and follow the instructions exactly! Repeat every 3-6 months and you should be fine. Good luck!
May 04, 2008 | Black & Decker Quick N Easy X420 Iron
Treatment of new iron
Before first use, remove any labels or stickers, on the body or soleplate of the iron. On first use only, iron over an old cotton cloth using steps 1 thru 5 below on setting 5 or above (and the SURGE button for models with that function) to remove any protective surface treatments. 1. Using a clean cup, pour water into one of the two openings in the Water Fill Hole until the level reaches the MAX mark on the Water Window (A). Refill as needed. 2. Ordinary tap water can be used for ironing. Do not use water processed through a home softening system. In extremely hard water areas, consider using distilled or demineralized water, however, use tap water the first time you use the iron and once a month thereafter to maintain steam performance.
Jan 01, 2006 | Black & Decker Quick N Easy X485 Iron
Black & Decker Quick N Easy X400 Iron Logo
Top Black & Decker Irons Experts
tfelton3
nmccully
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
