Question about Craftsman Garden
I got a extension spring that came off the center idiet bracket i put the spring on idier, but i dont know where the other end of the spring goes
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: MTD Yard Machine Model: 13RL771H029 46" deck Need
May I also get the serial # to help you with your problem
Posted on Jun 19, 2011
How do you remove the manual shift lever from a 1994 acura legend
YOU HAVE TO UNSCREW THE SHIFT LEVER KNOB. REMOVE THE CENTER CONSOLE.REMOVE THE RUBBER SHIFT LEVER BOOT AND THE DUST SEAL.YOU NEED TO RAISE SUPPORT VECHICLE ON JACKSTANDS ON LEVEL SOLID GROUND.YOU HAVE TO DISCONNECT THE EXTENSION ROD FROM THE TRANSAXLE.SIMPLY REMOVE THE BOLT THAT ATTACHES IT TO THE EXTENSION BRACKET.TO DISCONNECT THE SHIFT ROD FROM THE TRANSAXLE PUSH THE DUST BOOT FORWARD REMOVE THE CLIP AND DRIVE OUT THE SPRING PIN WITH A PIN PUNCH.DISCARD THE SPRING PIN.DO NOT REUSE IT.TO DISCONNECT THE REAR END OF THE SHIFT ROD FROM THE SHIFT LEVER REMOVE THE NUTS AND BOLTS.THEN REMOVE THE TWO NUTS AND WASHERS THAT RETAIN THE CHANGE BALL HOLDER TO THE UNDERSIDE OF THE EXTENSION ROD AND REMOVE THE CHANGE BALL HOLDER LOWER THE SHIFT LEVER DUST SEAL,SHIFT LEVER BALL SEAT,SHIFT LEVER AND EXTENSION ROD.INSPECT THE BUSHING AT THE FRONT END OF THE EXTENSION ROD AND REPLACE IT IF ITS CRACKED TORN OR WORN. REPLACE THE ORINGS IN THE BASE OF THE LEVER.BESURE TO LUBRICATE NEW O RINGS AND BUSHINGS WITH A SILICONE GREASE.USE A NEW SPRING PIN TO ATTACH THE SHIFT ROD TO THE TRANSAXLE.INSTALL EVERY THING BACK VISA VERSA.
Mar 02, 2011 | 1994 Acura Legend
Put a new top belt wont start we found a small soring but dont no where it goes went and started ok before belt went on . when turn key is like flat battery but had on charger not that help please
Hi
The belt goes on the top of the variable pulley and the transaxel pulley. There is a belt tentioner (flat Pulley) You need to remove the pulley and look on the bracket side closest to the clutch/break petal for a small hole for the spring. Put the spring hook in the hole through the top of the bracket, let it hang. Replace the pulley. Now remove the rear tire and rim on the left side of the mower. Clutch/ break is the left side. If you look where the tire use to be toward the front you will see the hole where the other end of the spring goes. The flat pulley goes toward the flat side of the belt.Pull the spring with a vice grip place the other hook in the hole.
Hope this helps
Terry
Jan 15, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
How to put together a toro recoil
first you put the rope into place then place the spring in the center lock ,if its out then you tighten up the spring by turning it in the direction that will pull rope back in once at the end of recoil send rope into pull hole, hold it tight and let it coil up slowly,reattach to machine and your done.
Jan 14, 2010 | 2005 Suzuki RM-Z 450
How to put the kick start assembly on my 2000 ttr 125i pulled the crank case cover off and the kick start assembly came out with it and i dont know how the springs line up and the rod goes back in
Go to the site below where you can see a parts diagram for your specific bike. Often seeing a diagram can help determining how it goes back together. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part and/or the notation "Not Available" is in the description, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
Basically you put the shaft into the center case, put the clip on the gear, put the gear on the shaft and rotate the clip into the spot provided below the shaft, mount the large washer, mount the spring guide collar, put the center of the spring into the end of the spring guide notch while the long spring extension hooks into the place provided in the center case. Now put the cover back on with the seal already mounted in the cover. Can I get a “very helpful” rating on this answer?
Aug 24, 2009 | 2003 Yamaha TT-R 125 LE
The spring from the back where you load the paper has pop out and I dont know where it goes, and now I can not print anything because the paper cannot go through? Can someone help and guide me to put
The location of the spring is located near of the sensor.The sensor is attached by the sweveld arm then install the spring in the center of the pivot area of the sensor.So that the sensor will goes up ,it need a spring to do the act.
May 28, 2009 | Epson Office Equipment & Supplies
I have a riding lawnmower yard machine 18.5 hp w/42 inch cut deck i am having a problem putting the deck back on there is a spring and hanging bracket that i cannot figure out where it goes. the only...
If this bracket is just like a heavy wire, it hangs from the right side of the transmission. It just hooks around the top of the housing and spring most likely goes from a bolt in the center of the metal plate at the back of the deck. If this doesn't describe your model, look under the seat for the model # and send a comment back. Lee
May 19, 2009 | Garden
Do know how to put drum brakes on
First you will need a brake spring wrench. This is like a 14" plier looking tool which will uninstall springs on one end of the tool and install springs using the other end. Remove the brake shoes and mount the new shoes one wheel at a time. You will use the other wheel as a reference when putting the new shoes in place. You may have a shoe retainer assembly holding each shoe to the backer plate. A normal pair of pliers will let you depress the spring and turn the spring keeper L or R to remove the keeper. Put your finger on the center pin from the back side of the backer plate so that it doesn't turn when you turn the keeper.
Mar 14, 2009 | 1994 Oldsmobile Eighty Eight
TrackMan Wheel Trackball Spring - where does it go.
it's not really a spring -- it's just a twisted piece of wire. actually, it's what makes your little scroll wheel click when you turn it. place the scrool wheel in the little plastic bracket that holds it with the longest piece of axel (hollow side of wheel) in. then TURN THE BRACKET OVER. the wire goes on the BOTTOM, which is quite counterintuitive. you'll see how it goes -- the smallest end of the wire goes INSIDE the scroll wheel and the kinda squared end of the wire goes into a little hole in the bracket. you'll understand when you look closely at it. once the wire is installed, hold it in place when you turn the bracket/ball/wire assembly over. fit the legs on the bracket into the groves on the base of the trackball -- that's the side where the ball sits and the circuit board is. make sure the scroll wheel passes through the trackball cover when putting it all back together. VOILA! problem solved.
Jun 02, 2008 | Logitech Cordless TrackMan Optical...
How to put the spring in
are you saying the spring to the door fell out and this is the second time??? how was it replaced the first time as a spring should not just fallout unless its dropped and a boss is broken off. ( a boss is a small plastic piece that would hold the spring in place.) This is a hard call unless you get the mechanical diagram as I dont have and they are all made differantly.
Mar 24, 2006 | Panasonic SL-SX430 Personal CD Player
Garden Logo
16 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
