Question about John Deere Garden
Stx38 where is curcuit fuse
Stx38 where is the starting circuit fuse located
I have a john Deere stx38 yellow deck Kohler motor does this mower have any fuses that has anything to do with getting fire
Hello I'm wade No it doesn't! It is all ran by key switch. If you can remove air filter and spay starting fluid in engine if it starts then you having fuel delivery problem. Fuel shut-off solenoid usually sticks not causing fuel to get into engine and that solenoid is what kills the engine when key gets turned off. If you have any further question I'm here to help. Wadembly@aol.com
May 07, 2015 | John Deere Garden
John deere troubleshooting
I have model 917-276900 tractor starts fine but when I engage the mower deck it blows the fuse and dies.
Aug 31, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
Need to know dose a stx 38 john deer mower have a pto relay or fuse
Yes, it has a relay located under the seat on the right side of the battery
Aug 27, 2013 | John Deere Pto Clutch For Stx38 And Stx46...
Starter relay location
Hi Anonymous, 1998 and later Sportster models circuit breaker and fuses were located in an electrical bracket behind the starter relay and data link that was mounted behind the left side panel. 1997 and earlier circuit breakers only no fuses were located under the seat. Good luck.
May 24, 2013 | Harley Davidson XL 1200 C Sportster Custom...
I have a John Deere l130 and the mower blades engage when I start the engine even when the PTO switch is off. Any suggestions?
sounds like you have feed going directly from switch as soon as you turn ingition to start mode ?
check wiring back from electric clutch to main switch
possible 2 wires have been placed on main switch instead of pto switch ?
or you have a crossed circuit somewhere (that is feed from another live circuit) not directly connected and its ended up at electric clutch as soon as you liven main circuit
a wiring diagram may help
check with www.johndeere.com
or www.jdparts and enter their site load your model and type
and go to electrical system and print out a copy of wiring diagarm
you may need to supply and user name and apply for password from john deere via their site apply on line
its a good site for info and parts diagrams
cheers hope it helps
paul
Aug 05, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
Stx38 won't start
Actually, this is a problem with many lawn tractors. John Deere makes a "Starter Assist Kit" that sells for about $25. After time, the electrical connections get a bit corroded and when you turn the key the solenoid doesn't get the full current it needs to be activated. I have made my own relay to overcome this problem on my STX38, have shared with many folks with positive results as well. Cost is about $5 total. If you still have this problem and would like a schematic of the "fix", go to:
Mytractorforum.com, go the the Lawn and Garden section, click on John Deere. When the page opens, search STX38 and look for the thread started by "Brad". Info is in there.
Good Luck.
Apr 06, 2009 | Garden
Garden Logo
158 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
