Question about Garden
Honda mower model hrr2166vka How do i adjust my smart drive control
2 Suggested Answers
  • 78 Answers
SOURCE: honda lawn mower wheel drive works, but needs adjustment, how?
Take the covers off the drive,there should be a hollow bolt the cable comes thru, it should have 2 adjustment nuts This lengthens or shorts the cable. There also may be a adjustment on the handle.
Posted on Oct 27, 2009
How to adjust control cable on troybilt mower model 11A 436 M011
follow the cable to the adjuster and adjust it it may be under drive cover
Aug 23, 2014 | Garden
Drive belt comes out
There is an adjustment to tighten up the drive belt tensioner pulley. You should be able too see it after you remove the safety shield. Tighten adjustment nut to snug belt.
Apr 20, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Honda mower drive cable
The drive belt may be worn and slipping on the pulley. (assuming it is a belt driven model). This would cause the mower to lose a great deal of power to the wheels. By adjusting the cable only, you are effectively adding a little more friction to the belt/pulley interface which in turn will provide a bit more power but the belt may still be slipping on the pulley(s) which is where you could still be losing the majority of your mowers self propulsion. Some Honda models may also employ a belt tensioner that simply adds tension to the belt even if the belt becomes stretched out & worn but the pulley's can become glazed (slippery). If it is a direct "pulley to pulley" drive with a single drive belt (no tensioner) the worn belt can also glaze the pulleys and cause further slipping. You can reface your pulley(s) contact surfaces with a very light grade wet sand paper (1000 grit), a coarse grade steel wool or a scotchbrite abrasive pad, thereby giving the belt more "purchase" on the pulley(s) contact surfaces. If you do perform a refacing of the pulley(s), it is strongly advised that you replace the drive belt as well. Your mower will then function as it did when it was new. Hope this helps.
Mar 29, 2014 | Garden
I have a Honda HRR2165VXA mower that is having issues with the smart drive.
hello, hello, Drive belt replacement for front drive mowers. remove the belt coved on top of deckand clean out grass,turn mower on side where carb is facing up,use a pair of vice grips on side of mower deck so the blade can stop,remove the blade,remove the belt cover and clean out the grass,remove belt from rear and front pulley pulleys. install new belt,put belt cover and blade back on,put front belt cover on, should work,if that is not the problem; wheels will not prepeal the mower,wheels turn only when raised off ground, Check the gears or groves on the inside of the wheel for access wear that is a common problem,check the axle drive gears to make sure turns ok, to check gear box if ok pull mower back wards while drive is engaged,if wheels turn backwards than the trams is bad,all of this is caused by the operator,by not disengaging drive while pulling mower backwards or by holding mower back not allowing to propel self completely,hope this helps,any comments welcome,thank you.
Feb 15, 2012 | Garden
Honda lawn mower wheel drive works, but needs adjustment, how?
Oct 25, 2009 | Garden
Blade won't stay engauged
It is very hard to say without knowing model, but if it is a Honda Harmony than I would look towards the the cable that controls the blade engagement. If your model is equipped with a blade engagement lever most likely yours is controlled by a cable also and it only needs to be adjusted correctly. Good luck!
Oct 18, 2009 | Garden
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
