Question about Samsung PCL541R 54" Rear Projection Television
Is the a certain type of HDMI Cable required or recommeneded for use with a Samsung PCL541R TV?
    Problem Solver:
Try and buy the one with gold tips.
Posted on Jun 24, 2009
Connect desktop pc to my samsung big screen tv?
match the display outputs on the back of the computer to the inputs on the TV. ..use Appropriate cable and switch TV Input to that type
No matching input ??
Search amazon for converter cable
DVI to HDMI usually work
VGA to HDMI can be problematic and not work
Amazon com DVI to HDMI
Nov 15, 2016 | Samsung Televison & Video
Hi I have a Samsung ht 350 home cinema,everything works fine good sound and everything but the only thing I don't understand is when I connect hdmi from it to the tv the Samsung goes in to prot mode??
Could be a faulty cable. Try changing the HDMI cable. Either that or the output from the TV is excessive. Check that the TV to make certain the HDMI output is the right kind.
Feb 14, 2016 | Samsung Audio Players & Recorders
How do i connect my samsung n10 to hmdi on my television
All HDMI connections require a HDMI cable with one end inserted into the source devices HDMI output and the other end inserted in the TV HDMI port. If you lack that cable TigerDirect has them. They come with different size ends, so make certain you know what connectors you require.
Jan 05, 2014 | Computers & Internet
What is the optimal cable type to connect the Samsung UN55B8500 to a DirecTV HD tuner? Are there specific TV settings to use for this cable type
The best cable hook up to use is the just the one HDMI cable. Just hook it up from box to TV and change the input selection on your TV to HDMI. Then on the Directv Box, change the resolution to 1080 for the best image.
Nov 09, 2009 | Samsung UN55B8000 55 in. LCD HDTV
What type of HDMI cable do I need to connect my DVD player to my HD Sanyo TV?
Make sure DVD player and TV have HDMI ports at back to hook with HDMI cable.
HDMI cable has standard plugs on both ends and its length can be different like 3 feet, 6 feet or 10 feet. Click HERE to buy required length HDMI cable.
Oct 23, 2009 | Philips Televison & Video
No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
May 26, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
SAMSUNG TV MODEL # PCL541R bulb not working
With the model number you gave, it comes back to a 2002 model in which DLP sets were not out yet. That's a conventional projection set with 3 picture tubes. Check the model number again?
May 22, 2009 | Samsung PCL541R 54" Rear Projection...
Television Won't Display Certain Cable Shows
Okay,i assumed this is what you have:
HD cable box with HDMI cable connection to the Samsung TV.
Listen careful as follow:
First you want to make sure using the same HD comcast box with HDMI connection for our Samsung TV as well as your other TV.Be sure the other TV do received the missing channels from the Samsung TV.You must be SURE you have tested both TVs with the same HDMI cable with the SAME HD cable box.
Now that you have confirmed the both TVS are using the same HD comcast box and the same HDMI cable but the connection that goes to the Samsung TV are missing some channels,at this point,use another HDMI connection behind your Samsung TV and see if you have the same problem.If so,please also try the left side of the HDMI connection and see if you could get the other channels.
Let me know!
solutiondoct
Jun 15, 2008 | Samsung HP-T4254 42 in. Plasma Television
Samsung PCL541R 54" Rear Projection Television Logo
43 people viewed this question
Jerry Greenberg
Jerry Greenberg
