Question about Juki Sewing Machines
When sewing every few stitches it will miss one
  • 64 Answers
Try changing the needle to one size larger otherwise your hook is out of time with needle.
Posted on Jul 21, 2014
dupina
  • 110 Answers
SOURCE: My Futura CE-150 beeps and stops sewing after only a few stitches
Look for the buttonhole lever, just in front of the presserlever, on the lefthand side of the machine. Pull it down and push it back to the top. Good Luck
Posted on Jan 10, 2009
bargainbox
  • 1388 Answers
SOURCE: my white sewing machine is skip stitching
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Posted on Aug 27, 2009
  • 1116 Answers
SOURCE: sewing machine locks up after first few stitches
Refer to the manual. The machine may need cleaning and general maintenance or service.
Posted on Mar 10, 2010
  • 980 Answers
SOURCE: when sewing the machine keeps missing stitches and
Try a new needle first if that does not work email me and I will attach timing instructions but tell me what make of machine you have, drivewithken@blueyonder.co.uk
Posted on Apr 10, 2010
  • 1564 Answers
SOURCE: My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Posted on Sep 03, 2012
How do I get it to sew?
was the presser foot lowered? check if the loop-taker is properly installed or seated.
Oct 03, 2015 | Brother XL2600I Sew Advance Sew Affordable...
Missing stitches
Please check the stitch regulator and check the bobbin tension and winding or you check the thread put properly. Otherwise you go to mechanic shop.
Mar 01, 2014 | Bernina Activa 130
It wont stitch tee/shirt material it misses stitchs
If machine misses stitches consistently, it can be several things.
Needle not installed correctly, not threaded correctly, Bobbin case not installed correctly, make sure the bobbin itself is inserted correctly and spinning in the correct direction.
Finally, machine may need service the timing is off. All actions of a sewing machine are carefully "timed" to form a stitch while sewing. Sewing things that were too heavy for the machine or you hit the bobbin case while sewing can knock the machine out of adjustment.
Let a professional do the maintenance on your machine. Some may opt to show you how to do more in depth maintenance yourself at home.
Cheers,
Feb 01, 2013 | Sewing Machines
Missing Stitches
if you have verified the needle is the right one for the machine model and in correctly (long groove the correct direction), that the bobbin is wound and in the case correctly, try a different material and/or thread. If the problem persists, take the machine to a better mechanic/shop. It sounds like it is out of sync. (hook rotation to needle throw).
Jul 06, 2012 | Janome Sewist 525S Mechanical Sewing...
I think the timing is out on my janome 2039 sewing machine
It is very possible that the timing is off, which often occurs with broken needles. A common symptom is that the needle will not pick up the bobbin thread. Missed stitches aren't necessarily timing related--be sure to install brand needles often and use the correct needle for the fabric & thread you are using. Using the wrong needle will often cause skipped stitches.
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Here What to Do if Your Sewing Machine is Skipping Stitches
Basic Maintenance Tension Skipped Stitches
You can search for sewing machine timing or take it for service.
Apr 12, 2017 | Janome Harmony 2039 Mechanical Sewing...
I have the same problem
Aug 27, 2009 | Kenmore 15208 Mechanical Sewing Machine
Sewing machine not stitching at all
SIX Layers !!!!
You really need a size 16 needle that won't bend and miss the hook by the sound of it....can you sew on less challenging thicknesses OK ??
If not, the timing may need adjusting...here is a link to assist:
HERE
Jul 31, 2009 | Janome 1017 Mechanical Sewing Machine
I have an Aldi Delta NM902-05 sewing machine which was stitching OK yesterday. Todya if it skipping a few stiches on the top sticth. My mum is the sewing whizz and she reckons it's the tension, however,...
sarah if the top tension is to tight it might slip stitches but as always when there is a problem with stitching you should change the needle and make sure it is in right.
Taking the needle plate of and cleaning with a fine brush around the bobbin and feeders will help and should be done regular.
Aug 19, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
18 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
