Question about JVC Televison & Video
The open/close door is "jammed" shut and I can't get it to open or close.
  • 10,594 Answers
Question does not show model number of your JVC DVD player.
Problem seems that loading mechanism is misaligned and got stuck. Need to open dvd player to reset timing and alignment of loading mechanism.
Let me know model number to locate mechanical exploded views some where for more help.
Thanks.
Posted on Jun 23, 2009
2000 Toyota Sienna power sliding door is jammed shut. Any solution?
Open the inside panel of the door by popping off the little white clips holding it on. The cable connected to the inside release button is either caught on something or has come lose. Check out this video - https://www.youtube.com/watch?v=MkC2OiOiE_U
Jun 10, 2017 | 2000 Toyota Sienna
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
Front door latch jams and door wont shut
It sounds like the jaws are close. you need to pull on the door latch lever and hold it open use something round like a punch. not your finger. and open the jaws. if the door latch is not bad your door should close and latch normal.
Feb 25, 2010 | 2004 Chevrolet Aveo
Driver side door on 1995 chevy express van will not shut
Chances are the door latch has closed without the door being closed.
Inspect the latch mechanism on the door. I suspect you will find that the latch is in the closed position.
Use a screw driver to take place of the normal jam pin in the latch apply tension ( like the tension that would be present normally opening the door) and actuate the door handle.
Make sure to lubricate once you do get the latch to open.
Jan 17, 2010 | 1999 Chevrolet Express
I have a bedroom door that won't stay open. When you open the door it slowly closes. Any suggestions?
Pull the top pin out of the hinge, place it on a hard surface, and strike it lightly with a hammer, giving it a slight bend. Tap it back into it's hinge slot. The slight bind should stop the self-closing, The self-closing is due to the door being hung off level.
Jan 09, 2010 | RTO M-D Building Products Carpentry &...
Doors freeze up wont shut close after opening interior light then stays on
Look at the end of the door where the latch is located. The latch may have flipped to the closed possition when the door was open.There is a U shaped piece that when the door hits the post on the door jam it flips up to hold the door shut.If you can get the passinger door open you can see what it looks like in the open position. If this is the problem just hold the door handle like you are opening the door and with a srew driver or even your finger you can push than U piece back down.To keep your door from freezing shut try putting sone silicone spray on a paper towl and wiping it on the rubber door seal.Spray a little on the door latch as well.
Dec 28, 2009 | 2001 Ford Taurus
Televison & Video Logo
65 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
