Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
How to trouble shoot ignighter for pool heater?
    Top Expert:
  • Raypak Master
  • 4,292 Answers
Disconnect it should ohm out at about 78 ohms at 70 degrees if open no good or shorted no good replace if voltage to gas valve when it should be firing bad ignitor
Posted on May 14, 2016
2 Suggested Answers
  • 1631 Answers
SOURCE: raypak gemini 53 pool and spa heater pilot iights but burnner wont ignight
to be more specific... All of your switches or safety sensors need to be confirmed that there is a demand for heat. and they are: toggle switch on, thermostat set for higher temperature, high limits not tripped, and pressure switch sensing that there is good water flow. if these are all a positive go, then the heater will accept this as a need to heat the water. This all appears to most people as very simple and easy to understand, except for the case of possibly the water flow issue and the high limits? If the high limits have an open circuit, there is nothing that you can do about that, they are bad and will need to be replaced. The pressure switch, if it has an open circuit, it is because there is not enough water flow, and the most common reason for that is, a dirty filter. It will need to be cleaned.
The thermocouple, or pilot generator, creates enough voltage, which is by the way under one volt, which is called millivolts, to open and close the gas valve, and operate your heater.
when all of the above is a go, the gas valve receives its voltage, which is a sign or indication, to open the valve and allow fuel to enter the burner tray which will then be ignited by the standing pilot flame at your pilot burner assembly.
if there is no ignition, you either have one of the switches above not confirming it is ready to fire, or the gas valve itself is bad.
Posted on Apr 26, 2015
Trys to ignight flame shoots out of top and then error code IF
Try cleaning the heat excharger, make sure the combustion air isn't blocked. Flane rollout is caused by a lack of free air.
Sep 06, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool heater fires up and starts heating the water outflowing into the pool, but only stays warm for 5 minutes or less then cools and stops heating
You are tripping a temp limit switch. You either have a bad switch which you can jump the wire to confirm. This is a trouble shooting technic only. Jumping the wire permantly might cause bigger problems.
Aug 17, 2009 | Hayward H Series Propane Electronic...
Pilot will light but heater will not ignight
You may need to replace the Ignition Module. Have someone check to see if it is sending power. I have the same problem and need to replace the Fenwal automatic ignition system. The part cost $390 - check inside the heater for the model #
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Trouble shooting Hayward pool furnace
Big enough propane tank? proper pressure reducing valve on the propane? Check both of those.
May 30, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool heater not working
sounds like it is not getting enough water flow. Check to see that there is water going out of the heater. Here is a site you can check trouble shooting guide.
Feb 21, 2009 | Sta Rite Sr333lp - Max E Therm - Pool &...
Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Feb 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
