Question about MicroFridge 2.7 cu. ft. Refrigerator & Microwave
Microwave starts slow
Microwave turntable starts slow but gets up to normal speed within 20 seconds
My microwave keeps running
Thank you for your post, Lou!
From my understanding your Frigidaire microwave continues to run and when you press the second key your turntable will turn. This sounds like a potential issue with your keypad or control panel. I would recommend performing a reset on your microwave and you can do that by disconnecting power from it for at least ten minutes. This will help clear out any miscommunications within your microwave. If that does not correct your issue I would suggest seeking assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Jun 05, 2015 | Frigidaire Gallery FGMV154CLF 1.5 cu. ft....
My microwave oven siows down and then speeds up.
Is it still heating food properly? You can perform a basic test with a microwave safe mug or plastic cup of water. It should be boiling or too hot to touch within 1 to 2 minutes. Be careful not to overheat the cup if plastic and use extreme caution when touching or removing it from the microwave.
If it is not heating properly then the magnetron may be faulty and unit should be replaced.
Can you tell what specifically is speeding and slowing? Is it the turntable or the humming sound of the unit itself? Many microwaves vary their intensity in order to heat/cook evenly and that will vary the pitch of the sound you hear and sound like it is speeding up or slowing down. If the turntable is slowing and speeding up then there may be a bad motor and the unit should probably be replaced.
If the unit is heating adequately and the turntable speed is uniform then what you may be hearing is simple power cycling and/or fan noise.
Only trained and certified technicians should attempt repair of microwaves due to the hazards of high voltage and microwave radiation leakage if parts are not replaced properly. Although you can have a microwave repaired the cost may be equal to, or higher than, the cost of an equivalent new unit for a 900w microwave.
Feb 28, 2015 | West Bend 0.9-cu. Ft. 900-watt Microwave -...
How do I remove the white plastic turntable plate that moves the wheeled legs of the turntable??
inside the cabinet, there is (usually) a belt that turns that gear, you will have to unplug the unit and take off the cover to get at it, probably has some grit in the belt or such, also look for missing teeth
Jan 12, 2015 | Microwave Ovens
Sharp R-405H microwave turntable doesn't rotate and makes strange noise
Replace the turntable motor, it is defective and will only get worse.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
HMV Radiogram Turntable run slow at the start,
you should check under the table.
if it's a roller drive there, you can use water to clean the roller rubber and the inside edge of the platter.
If it's a belt drive, take it out and measure the length and get a replacement belt of same length
Jul 27, 2010 | Audio Players & Recorders
Turntables lags on pick up
I have the same exact problem with one of my 1210 MK2 turntables. It seems like the motor is too slow now. When I hit the start button or release the record, it takes much longer to speed up to the normal speed than my other same exact turntable. I don't think it has anything to do with the pitch slider. Please let me know if you find out what the problem is thanks!
Mar 18, 2009 | Panasonic Technics SL-1210MK2 Turntable
Slow start
There is something wrong with your drive system. Unfortunately, you will have to have a service professional take a look at this.
More than likely one of the Integrated Circuits (IC's) have gone bad and will need to be replaced - a common issue on the newer models.
- OPTiC
The 1200s Expert
www.1200s.com
Sep 06, 2008 | Technics SL-1210MK5 Turntable
MicroFridge 2.7 cu. ft. Refrigerator & Microwave Logo
21 people viewed this question
Top MicroFridge Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a MicroFridge Refrigerator Expert? Answer questions, earn points and help others
