Question about Bosch Dishwashers
Model shu3002uc dishwasher leaking from bottom , how to determin the age of this unit
reg501
  • 413 Answers
SOURCE: Dishwasher doesn't drain fully
Some model 665 DW have a check valve that is attached between the sump and drain hose that may have a blockage..... Remove the drain hose from the long plastic valve then carefully unscrew the check valve from the sump. Inspect for debris.
Posted on Jun 02, 2008
  • 338 Answers
SOURCE: Dishwasher door leak
at the bottom of the door is going to be the door seal starting to go bad. replace the seal
Posted on Dec 01, 2008
  • 82 Answers
Hello. Are you using liquid or powdered soap? In some models liquid soap will foam up and the drain motor can't pump out bubbles. Foaming can also happen if you pre-clean your dishes with liquid soap used for washing by hand. If it is foaming, you can poor non-dairy creamer or cooking oil into the bottom of the unit while it is in the wash cycle.
If foaming isn't a problem then the water level switch may be bad, the pump may be not pumping out as quickly as it should or you may need to take the hose off completely to make double sure that there isn't anything in it.
Did you check the air-gap next to your kitchen sink faucet. If you don't have an air-gap it may be hooked up to the garbage disposal and if you don't have a high loop in your drain hose the water can run back into the dishwasher especially if the disposal backs up.
Posted on Dec 03, 2008
SOURCE: bottom of dishwasher leaks even after the last rinse water has been drained
need a dwg on how to plumb a dishwasher
Posted on Jun 04, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore dishwasher leaking from bottom of door
This is commonly caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps. The silverware tray (if located along the left or right side) can also cause damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub. The only other items that can contribute to leaking are:
1. A dishwasher that is not level, which causes the door not to seal properly.
2. The inner door panel being warped causing the door facing not to be even for the gasket to seat properly.
3, Dish placement. If you place bowls, serving trays and large tumblers in the front row of the bottom rack on some dishwashers it can contribute to water being deflected over the front edge of the tub and out the bottom of the door (Believe it or not, I've seen it happen).
NOTE: Most dishwashers do not have a seal across the front lip of the tub. That's why it's important to have a good door seal and to load it properly.
If you've loaded the dishwasher properly and confirmed it is level (front to back and side to side), then here are your options:
1. Replace the inner door panel at a cost of about $115.
2. Replace the door seal at a cost of about $35-$40.
Parts can be purchased from any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Use whatever parts source you like, but I have found these to be the cheapest and most reliable sites to order parts from. Shop all of them for the best price.
NOTE: The inner door panel is listed under the Door Parts section. The tub gasket will be listed under the Tub Parts section.
I think I would pursue the cheaper option, first. Its also the much simpler option. To replace the door seal, follow these steps:
1. Pull the old door seal from the groove around the wash tub facing. Take note of which surface area of the gasket is inserted in the groove and which surface is facing the door. It may not seal properly if you install the gasket the wrong way.
2. Clean the area really well to ensure there are no food debris or soap deposits. Also clean the inner door area where the door meets the gasket. You need a clean surface for the best results.
3. Locate the center mark of the new gasket. This will be a small paint spot or small groove on the gasket (this surface is the side of the gasket that will be inserted in the groove around the tub facing). If there is no center mark, fold the gasket in half and mark the location with some chalk, or hold with your fingers.
4. Locate the top center part of the wash tub facing and align the center mark of the door gasket at that point. Begin pushing the gasket into the groove with your hands and work your way around and down along each side.
5. Make sure the gasket is inserted all the way around the tub facing to the point where it meets the wash tub bottom. You can pull the gasket out and readjust as necessary.
This repair should take you about 30 minutes or less to complete. Its simple and requires no tools. The door will be tough the shut for a while until the gasket compresses and takes the door shape. Do not slam the door if it becomes difficult to shut. Simply close the door and the push firmly at the point just above the door latch until the latch clicks. Slamming the door can damage the control panel components, the door latch and/or the hinges. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Sep 10, 2009
Bosch Dishwasher model #SHU3002UC-06 continues to run on any cycle, does not stop at the timer shut off spot
Anti flood device in a lot of german machines and pump keeps running only way to knock it off is too un plug what has happened water has leaked possibly over a period of time ,and set the anti flood device off if ya disconnect macine plug and drain hose and lie on its side water will drain off anti flood put some towels to catch water and macihne should work after ya reconnect
Nov 01, 2015 | Bosch Dishwashers
Determine age of Bosch dishwasher
This is the FD number eg
9001
add 20 to first two numbers 110, ignore the first number this is 2010, the last two numbers is the month 01=jan
8804 would be 88+20 108...2008 april
If you can't work it out please comment with FD
May 28, 2013 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dwl4035mbss
As a homeowner call a serviceman. Otherwise as a serviceman familiar with operational safety, remove the front kick plate cover at the bottom of the unit and then with a flashlight find exactly where the leak is coming from. The door seal or the drain pump? The intake hose or the drain hose? Determine if the unit is filling or draining or washing when the leaking starts. Then we can determine how to fix it.
Feb 24, 2013 | Haier Dishwashers
Determining age of kenmore dishwasher
2003.
bottom corner, last page of owners manual lists printing date
http://www.managemylife.com/mmh/owner_manuals/10323/KENMORE-Dishwasher-L0504241?brand_name_search=665.1633
Aug 27, 2012 | Kenmore Dishwashers
Trying to determine its age
Only from the manufacturer you can find. If you can note the Model No Sr. No of the machine, it is possible. If it is a discontinued model, it may not be possible.
May 20, 2010 | Frigidaire 24 in. FDB635RF Built-in...
I have a bosch shu3002uc that is leaking at the bottom of the door. I have to put sponges on the floor to catch the water. What should i do?
Check the levelness of the dishwash. Is it level.
Check the seal around the contact surface of the door and the washer opening. Are there any cuts or gaps?
Apr 25, 2010 | Bosch 23 in. SHU3302UC Built-in Dishwasher
My ASKO 2805 is leaking from the bottom during washes now...i think the gasket or something might be aged....where can I get parts and is this the typical repair problem.
yes it is probably leaking from the motor seal if they dry out at anytime they tend to leak or it is just age it is located at the top of the motor usuallky in the centre of washer in bottom...I suggest you call a good appliance repair and parts shop and ask about your particular model give the model no and year if you have it....good luck
Dec 25, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Dec 03, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Nov 24, 2008 | Dishwashers
Dishwashers Logo
14 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
