Question about Sharper Image Dryers
How do i open s1698 fan to clean - Sharper Image Dryers
How can I tell if a Sharper Image S1698 Air Purifier is working?
Turn it on high. Put a kleenex up to the intake or discharge screen. It will push it away or pull it towards the screen depending on if you are on the intake or discharge side of the unit.
Jan 21, 2015 | Sharper Image Air Purifiers
I need to open my fan/heater to clean it but there are no screws to take out. How do I open this so I can clean it. It has a lot of dust.
Some unit may have snap on covers and no screws. Some you can twist and take cover off. Some may have little taps that covers both front and back covers, just pull taps up.
Sep 11, 2014 | Refrigerators
Icannot open fan to clean.
If your tower fan is like mine then in the handle there are two screws holding on the back just remove those and it comes apart.
May 30, 2012 | Dryers
I cannot open to clean
There are two screws in the handle remove them and the back panel comes off if they are tower fans
May 30, 2012 | Lasko 2517 Tower Fan
Is this fan capable of being opened, because it has become dirty and I would like to clean it. Thank you
You can for sure open it and clean it ... use Proper Tools and Protective equipments . Unplug Supply wires before opening
Please Rate My answer well and Support me !!!
Nov 22, 2010 | Lakewood LAKWC1600 Floor / Box Fan
How do I clean the Lakewood Tower Fan LWTF-42/RC-DLX. How can I open it to clean the blades
Open the grills and use a long stem tipped with cloth dipped in kerosene to lightly clean the dust. Then use a similar arrangement of dry cloth wound on it to wipe clean the moist dirt. Repeat the process and you will have a clean blade. Use a jet air blower to assist you , use face mask and do it out in the open.
Helpful ?
Aug 20, 2010 | Lakewood 007 Floor / Box Fan
Need cleaning, not good output
OPEN THE INNER AND GET THE FAN ND CLEAN IT
Jul 10, 2009 | Lasko Stanley High Velocity Blower Fan...
Opening Vornado fan (model EH1) for cleaning
How do I open vornado fan (model eh1)so I could clean fan blades?
Jul 03, 2009 | Vornado Circulating Fan
Cleaning Honeywell table fan
By the way please check my video on YouTube for your answer. Watch, Subcribe, Share, and Comment!
Thank you
" How to Open a Honeywell Fan to Clean" on YouTube
Jun 14, 2009 | Honeywell HT-800 Table Fan
Opening fan
first open your cpu cover carefully ,by opening the screws once your cpu cover is opened then carefully remove the wire of the fan connected to the motherboad then open the screws of the fan and clean it then do the same just connect your fan to the motherboad and screw it up and its over make sure that your fan is working and its over
Nov 10, 2007 | WeatherWorks CH-V18 Floor / Box Fan
Dryers Logo
70 people viewed this question
Top Sharper Image Dryers Experts
Are you a Sharper Image Dryer Expert? Answer questions, earn points and help others
