Question about Miele Refrigerators
Miele Refrigerator error code _F 01 21. What is the problem and how to clear it.
The following code is being displayed on my five year old Miele KF1901vi refrigerator/bottom freezer model. 21 _F 01. I am not sure of the order of the codes but this is what it is displaying. I just recently changed out the water filter and the machine did make ice using the new filter. I also cleared the filter message light.
5 Suggested Answers
SOURCE: water in bottom of fridge
Thanks to all who spent money or shared their experience to have somebody do this repair, and I really mean it.
I have a Whirlpool TopLoad Fridge (not a side by side).
Things you'll need
30 minutes
Small socket for cardboard panel on lower back and panel inside freezer
Bicycle Pump
4 Towels
Hair Dryer
1. Take everything out of freezer
2. Turn dials off in fridge for both compartments
3. Pull fridge out so you can get behind it and unplug it
4. Be vigilant of ice maker line if installed
5. Pull cardboard panel off on back
On the left side you should see the back of the skinny drip pan and a small line. That line goes from the freezer and is most likely clogged.
6. Blow dry the back of the freezer enough so the ice is thawed at the bottom of the back panel.
7. Remove the two screws on the back panel. You may just be able to pull it toward you enough to get behind it. You'll see the coils and fan, and underneath these you may see some ice sheets and there should be a hole. That is the drain line that is clogged. I heated up some water and poured it over the drain to thaw the line. You may want to remove the crisper drawers and put some towels down there to catch the overflow. Once the ice is thawed enough at the drain. Go to the back of the fridge and place the end of the bicycle pump at the bottom of the drain hose. Apply pressure to get a good seal but keep pumping. You may have to go back and forth between pumping and thawing, but you'll know it is clear when you hear air going into the freezer and then the wonderful moment when water drips into the drip pan as advertised!
Keep those fridges less full so that the door stays sealed and keep the seal clean and also keep your doors from having too much stuff so the weight of the door doesn't pull away.
Okay, put it back together, turn everything on and be careful of your cord and lines when pushing the fridge back. Thank the Lord ours has wheels and man,was it cruddy underneath. Vacuum those coils underneath the fridge too for proper air circulation.
Blessings to you!
tay
Posted on Jan 11, 2009
SOURCE: Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
Had the same problem. I noticed that the fan in the freezer never shut off so I suspected the thermostat. I ordered and installed a new thermostat (about $30 and 15 minutes to install), the fan now cycles correctly and the ice build up is gone.
Posted on Dec 14, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore model 795 77563600 refrig side
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
heatman101
  • 43501 Answers
SOURCE: why is there heavy ice
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 25, 2010
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
This morning, my Frigidaire FFHS2322MS refrigerator had a pond of water in front, the compressor was clearly off and the lights inside were on. No error code of the displays, they were just bla
Have a technician test the start capacitor on the compressor. When they go bad the motor will draw excessive current which trips the thermal overload switch on the compressor. It usually resets itself once the compressor case has cooled down.
Nov 15, 2015 | Frigidaire FFHS2322MS 22.6 cu. ft. Side by...
I forget the pin code for my 61' toshiba tv how do i clear it
Dont know what model or how old your TV is but try this,
While the enter PIN code screen is displayed, press the RECALL key four times within five seconds and the PIN code will be cleared so you can enter a new PIN code but it has to be with the original remote. Worked with my old Toshiba TV about 2 years ago.
If it doesnt work I only waisted about 10 secounds of your time and I'm sorry.
Nov 13, 2011 | Toshiba Televison & Video
Code e on only two of the right hand zones on siemens induction hob
Hello.
These codes mean that the oven's electronic control hasdetected a condition it needs to check which mean error. When you see a code,follow these steps to solve the problem:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on.
Thanks.
Sep 07, 2011 | Microwave Ovens
Washer is showing E12 error. Help
Hello.
This code means an error code. That the dishwasher electronic control has detected a condition it needs to check. When you see a code, follow these steps to solve the problem:
· Press "Stop/Clear" to clear the display and stop the beeping if any.
· Reprogram the dishwasher.
· If the code still displays, turn off the power to the dishwasher at your breaker box and wait five minutes and clean all part (area) that are open to water carefully before turning it back on.
Thanks for using fixya
Aug 02, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Hi..Telmann tel6tl displays fault code E3..have you any ideas.. Thanks.
HELLO.
This code (E3) means an error code. That the dishwasher electronic control has detected a condition it needs to check. When you see a code, follow these steps to solve the problem:
  • Press "Stop/Clear" to clear the display and stop the beeping if noted then .
  • Reprogram the Washing Machine.
  • If the code still displays, turn off the power to the Washing Machines at your breaker box and wait five minutes and clean all part (area) that are open to water carefully before turning it back on for operation.
Thanks for using fixya.
Jul 31, 2011 | Washing Machines
E4 error code comes up when you turn on dishwasher
Hello.
  • Press "Stop/Clear" to clear the display and stop the beeping if any.
  • Reprogram the dishwasher.
  • If the code still displays, turn off the power to the dishwasher at your breaker box and wait five minutes and clean all part (area) that are open to water carefully before turning it back on.
Jul 31, 2011 | Dishwashers
Error code
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly
May 18, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox Workcentre Pro 215
This should resolve that fault code
Jan 24, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Refrigerators Logo
416 people viewed this question
Top Miele Refrigerators Experts
AJMAL KHAN
JonSnell Electronic
JonSnell Electronic
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
