Question about Gaggenau Refrigerators
Refrigerator door alarm
The door alarm doesn't go on if the refrigerator door is accidentally left open. How could this be fixed?
aborcass
  • 2651 Answers
SOURCE: left refrigerator door open over night, next day it stopped working
sounds like you sucked in a lot of warm air over night freezer still working? just the refrig went out???easiest solution empty unit completly, unplug and leave doors open let al frost melt out 24 hrs later plug back in and you should be find
Posted on Feb 23, 2008
  • 210 Answers
SOURCE: LG Bottom freezer refrigerator LRFD25850ST
You will have to buy a new board to solve it.
Sgt 48
Posted on May 31, 2008
  • 272 Answers
SOURCE: we have an alarm on
if you let me know what brand refrigerator..i can tell you better, but most have a on/off for alarm...
Posted on Jan 11, 2011
  • 2509 Answers
SOURCE: Door open alarm sounds and door open indicator
The switch which detects whether the door is open may be malfunctioning or the control unit to which the switch is connected is faulty. If there is only one switch it may be the same switch which puts the light on as you open the door.Does the light come on when the door is open? If so the switch if there is only one, is probably ok but the control unit is faulty.Look around the edge of the door frame for switches and check they are not stuck or damaged. I hope I have been of help but please do not hesitate to ask if you have any further questions.
Posted on Feb 20, 2011
  • 5370 Answers
SOURCE: Freezer door was accidentally left
If the freezer or fridge door remains open for one hour or few more hours by mistake, then to again get to its proper cooling cycle, it requires approx another 24 hours.And in that also, dont open the refrigerators doors for few hours.If you open, close it quickly.Once it cooling cycle again gets set, then you can use it like you use regularly.But approx it takes 24 hours to get proper cooling.-------- ------------------ But if its already more then 24 hours and there is very low cooling, then it can be internal defrost cycle issue.You will have to do manual reset procedure.The manual reset procedure is as follows:-------- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check,it will get set to its cooling cycle and work as normal.------------- This should help.Thanks.Helpmech.
Posted on May 04, 2011
The door was left open more than 5 minutes, the alarm went off and the lights went out
Some newer refrigerators have a timer that turns off the light after a given amount of time. The alarm may be there to alert you that the door is open.
Aug 01, 2016 | Maytag MFI2568AES Stainless Steel Bottom...
Hotpoint FZFM171 freezer door left open all night, has defrosted and the 'super freeze' light and alarm light wont stop flashing. How do we fix it?
Turn the power off to the refrigerator and manually defrost the freezer until the freezer bis no longer cold and then replug the power cord
.APPLIANCE 911
Jan 27, 2016 | Hotpoint Refrigerators
Why my alarm wont come on when door is left open
there is a short circuit in wiring. please check its wiring
Oct 15, 2015 | Samsung RF265AA Bottom Freezer French Door...
Alarm went off, now the central locking doesn't work
use the car key itself from outside the vehicle with everything closed: use key in drivers door outside door lock and manually lock and unlock the door. check if fixed, may have to do a few times. i do believe the vehicle is in theft mode.
Aug 18, 2012 | 1994 Volkswagen Golf
I replaced Refrigerator Electronic Control hv board and I can't program it successfully? DOthe doors need to be open to program?
1. Open the Fresh Food door and press and hold the Door Alarm keypad DoorAlarm .
2. Press and hold Refrigerator Temperature UP keypad .
3. Release the Door Alarm Keypad DoorAlarm and wait 3 seconds.
4. Press the Refrigerator UP Keypad again.
5. Display will show 001 in left display and numeric or dashes in right display.
6. Press Freezer Up keypad and Freezer Down keypad to toggle through Service Test numbers
Aug 13, 2011 | Maytag Refrigerators
Bell tone
DOOR ALARM IF LEFT OPEN LONGER THAN A MINUTE. OR REGULAR DOOR ALARM EVERY TIME IT IS OPENED. THE MANUAL MAY TELL YOU MORE.
Apr 25, 2010 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
16 people viewed this question
Top Gaggenau Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Gaggenau Refrigerator Expert? Answer questions, earn points and help others
