Question about ADATA ASH93-500GU-CBK Hard Drive - Superior SH93 500 Gb 2.5" External Black USB 2.0
Driver for adata superior sh93 windows 7 download
Divers A-DATA C906 windows 7
Looks like ADATA only supports windows XP. However, Windows 7 should recognize it natively.
http://www.adata.com/index.php?action=ss_main&page=ss_content_driver&lan=en
May 10, 2014 | ADATA C906 16 & 32GB USB 2.0 Drive
Driver for adata c008/8gb xp sp3
Try looking here:
Mar 24, 2014 | ADATA Classic Series C008 Retractable 8GB...
Adata superior SH93 on macbook pro cant see drive
If the drive is formatted for anything but a MAC, for example Windows, The drive will be seen but not data will show as the mac cannot read most Windows file systems. Try connecting the drive to a windows machine and see if the data can be read.
Mar 10, 2014 | ADATA Superior Sh93 500 Gb External Hard...
Driver for adata superior sh93 500 gb external for windows 8
you dont need a driver.
i cant find SH93?
the top complaint it the USB cable is no good.
or falls off, or likes to get half/inserted and fail.
try a new USB cable.
see if windoz (is it on a mac?) disc managment can see it.
see if windoz) lick USB task bar icon can see it. (1st)
when you plug it, in to USB port (yes, try them all, and other systems.) the USB port goes dingdong, (connect sound)
does it?,
if , not it for sure did not connect. fix that first.
Sep 29, 2013 | ADATA Superior Sh93 500 Gb External Hard...
Unreadable external hard drive
I would suggest http://FreeDataRecovery.us
They offer both online data recovery and do-it-yourself data recovery services.
Sep 07, 2012 | ADATA A-data Sh93 Portable 500gb 500 Gb...
Beyluxe invalif login Windows 7 Home Premium
look on the pirate bay and download a new copy or a crack for this one ,also look on sourceforge.net as on the euroepon goverment site you can download a copy of linux for free which is far superior to windows
Jan 19, 2012 | Microsoft Windows 7 Home Premium 64BIT...
I'm looking for the pentax optio S5i usb driver for windows 7
Sorry, you won't find one for Windows 7 as the camera is discontinued and no longer supported with software updates by Pentax.
But you may be able to use the Compatibility Wizard built into Windows 7 to run the XP version of the software. If this fails then your only remaining option is to use an external memory card reader to upload images. I'd recommend that you do so anyway as it's usually much faster and gives you a genuine choice between Windows own image handling and editing package (pretty good) or genuinely superior alternative software which is often free. Picasa is one of many popular alternatives.
I hope that my reply has answered your question; if so then please take a moment to rate my answer or add a comment if you need further assistance with this problem and I'll respond when I'm next online.
Sep 13, 2010 | Pentax Optio S5i Digital Camera
I install W7.my sound has not working
The lenovo 3000 Y410 is part of their budget range and lenovo decided not to officially support Windows 7 for the hardware. However we have one that we use in the kitchen which we have been able to successfully upgraded to the far superior Windows 7 operating system.
In order to get the sound card working I tested the Windows XP and Windows Vista drivers.
As it turns out the Windows Vista driver supplied by lenovo worked fine for me.
Therefore to fix your problem, download and install the Windows Vista soundcard driver for your laptop which can be found here-
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-68104#audio
Thanks,
javaftper
Aug 05, 2010 | Lenovo 3000 Y410 Laptop
Download Windows XP on new mother board Tktnologia
Hi I am vortash I have to say the only time I have come across this is when the system is equipped with on board HD graphics and Audio Bus driver requirements .. these modern drivers are not a normal requirement of XP and therefore it would not contain a drivers cab with the information required to set a system like up ,so it raises an error message . Especially now with Machines that use Quad core CPU's and in some case's duel core .
Most modern Laptops that use single core and standard audio have no problems with XP .. Microsoft has taken this on board well with the release of Windows 7 the new Beta program now available for free with a 12month trial basis in some areas it has a far superior data base of drivers available to it and should address any problems .. if you where lucky enough to register earlier this month you will have been given a key code to use and install any download of windows 7 some may still be available on the net .. windows 7 downloads certainly are from Microsoft themselves for one place .. and no doubt on Bit Torrent this trial is for 12 months then the program will shut down so install it on a secondry partion so that when it does you can go back to your old operating system to recover any files . I hope this has been of help top you Regards Vortash
May 13, 2009 | Computers & Internet
ADATA ASH93-500GU-CBK Hard Drive - Superior SH93 500 Gb 2.5" External Black USB 2.0 Logo
530 people viewed this question
Top ADATA Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
dmhandyman
Are you an ADATA Computer and Internet Expert? Answer questions, earn points and help others
