Question about Huffy Raven 26-Inch Dual-Suspension Mountain Bike
Back wheel assembly is wobbly - Huffy Raven 26-Inch Dual-Suspension Mountain Bike
  • Anonymous Mar 24, 2014
    took off fenders and now wheel wobbles and "clicking" noise with each pedal....
If the wheel wobbles it may be the cones are loose (these are the next bolts along from the nuts that hold the wheel on and they have a locking nut) so these need to be adjusted to stop any play in the spindle whilst still allowing free rotation of the spindle then the wobble should have gone .
Posted on Jun 23, 2009
How do I get the back wheel to stop wobbling and rubbing the side of the mower?
Hello. My guess is that if the wheel is not bent or broken around the spokes and is snug on axle, then you have a wheel bearing out. Simple to find and replace. Good luck.
Apr 01, 2016 | Craftsman Professional 775 Torque 175 cc...
My back tired on drivers side of my mercury mountaineer 2006 is wobbling back and forth
Make sure wheel nuts are tight. If they are you may have broken/seperated belts in the tire. Have the tire inspected. If ok I would check for loose wheel bearing/hub assembly.
Apr 07, 2015 | Mercury Cars & Trucks
1996 Subaru has a loose tire
wobbling back and forth, could mean a tie-rod needs replacing. Try moving it up and down. If it wobbles up and down also then it probably is the wheel bearing!
Jun 13, 2013 | Depo Auto Parts Subaru Legacy/Outback New...
The front wheel of my yamaha 80 wobbles when I am riding my bike. what is wrong
There can be two issues related to this problem.
The front wheel can be off balance on the bike. This means you will need to balance the wheel using a wheel balancer.
Secondly the wheel bearing could be faulty and result in wobble. You will need to check the front assembly fully, check the suspension and shaft.
Feb 17, 2011 | Yamaha YX 600 Radian Motorcycles
The front wheel wobbles when it's on swivel, what
The wobbling front wheel problem is easily solved. Simply remove the two philips screws from the plastic cap covering the from wheel assembly on the foot plate. (Where the break cable goes into the swivel tube) Now tighten up the large black nut with a spanner, replace the black cap and your done!
Mar 06, 2010 | Jane Baby Gear
Side to side wheel play
It could be an indication of a bad wheel bearing assembly. Did you check the lug nuts to be sure they are tight? It could also be the tie rod assembly. I would take off the wheel and try to move the just the hub assembly. Do you hear any screeching/squealing noises? Any popping while you are driving? Are your tires wearing? All these are classic signs of a bad wheel bearing. Any decent tire/auto shop can put your car on a lift and check the wheel bearings.
Jul 24, 2009 | 2001 Dodge Stratus
I have a 1992 ford taurus that has developed a wobble & thump in the front wheels the faster I go the faster the wobble gets thanx gevinsky
what you have described is what happens when the wheel Bearing/Hub Assembly goes bad and needs to be replaced about a $80 part
Dec 10, 2008 | Ford Taurus Cars & Trucks
Cause of wobble in front end on 1992 ford taurus
Dec 10, 2008 | 1996 Ford Taurus
Front wheels noisy and wobbles
You have a serious problem.
Check lug nuts for tightness first.
If not that then take to mechanic, as you may need CV joints (constant velocity).
Jun 16, 2008 | 1999 Mercury Sable
Huffy Raven 26-Inch Dual-Suspension Mountain Bike Logo
316 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
