Question about Lincoln X2471 2 Yr Extended Warranty For 140c
Why does my lincoln 140c cut out? - Lincoln X2471 2 Yr Extended Warranty For 140c
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Had the same issue with a friends SP125
Just got to looking at the Welder. Here's what I found. Yes, the Drive motor would thermally shutdown even if I holding the trigger and not welding. Ends up that there thermo sensor is not too sensitive, it ends up that the two pointed nodes on ether side of the Drive wheel were gummed up. A simple loosening of a screw to get them out. Cleaned them with Brake Cleaner and a paper clip and it took all the restrictions out. When trying to pull the Wire out of the Gun it too was tough to get out. Added some mineral spirits to that ( figured Brake cleaner was too aggressive) and it helped a lot. Working good now.
Posted on May 20, 2015
If fan element fails on a Smeg dual fuel cooker will it stop cooker from turning on? The clock works but no other lights. Cooker not set to Auto. Is there a fuse or other power cut off? Checked topThermal...
If there are other touch switches that are not responding, then the fan failure might not be your problem. If might just be the electronic control board itself. Before you speak of 'fan failure' check the board to see it it is responsive.
The clock will always work even with fan failure.
Check all the wires and harnesses to the control board...unplug and replug them back in.
What is a 'fan element?'
Oct 23, 2013 | Smeg Kitchen Ranges
Hummingbird 140c power problem
I am having an issue getting my brandnew 140 C to turn on. Fresh batteries... Called customer service, they want me to send it in. Ill update you when I find out what the issue was...
Mar 28, 2013 | Humminbird 140c Fishin' Buddy
What speed can I use a humminbird 140 c
wouldn't recommend anything more than a slow idle . much faster might break the clamp off and U would lose it overbaord
Apr 18, 2010 | Humminbird 140c Fishin' Buddy
My lincoln 2001 cuts off while iam driving any
"Cuts off while driving" narrows it down to about 20 causes. Take it to a mechanic.
Nov 23, 2009 | 2001 Lincoln Town Car
Humminbird 140c randomly shuts off
check power cable or see if battery is loose
Jul 30, 2009 | Humminbird 140c Fishin' Buddy
Is the Humminbird 140 Fishin Buddy water proof?
most graphs are....... UNLESS damaged or dropped....see you on the water...GL
Jul 04, 2009 | Humminbird 140c Fishin' Buddy
Cannot get machine to turn off with killswitch
check toggel switch,sounds like it is stuck in closed position.
Jun 27, 2009 | Lincoln X2471 2 YR EXTENDED WARRANTY FOR...
Just found a fishing buddy 2 fish finder in a skip. It goes but can't work out how to use it. Does it have a manual?
It has an online manual to download.
do a search for humminbird 140c.
some portables only work at very slow speed or sitting still in water.
Jan 15, 2009 | Humminbird 140c Fishin' Buddy
Lincoln X2471 2 Yr Extended Warranty For 140c Logo
186 people viewed this question
Top Lincoln Welding Tools Experts
Steve
joe2639
Level 1 Expert
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
