Question about Boston Harbor CF78125 Ceiling Fan
I have a clicking noise in motor housing. Is it a bad motor? Just installed.
Inducer Motor Noise
Bad induction assembly is common with these units. If it's the style that has the motor install in what looks like a square black plastic box with tube connections off to the left and right. Replace the whole assembly, not just the motor. If you are mechanically inclined replacement isn't to hard.(make sure electricity to furnace is off). Cost to purchase induction assembly(look online) is around $300. If you have a company do it expect a bill between 650 and 800.
Mar 14, 2014 | Bryant 352AAV036060 352AAV 60,000 BTU, 92%...
Pontiac g6 2006 heater/ac fan doesnt work on #3 speed setting, fan made squealing bearing noise for a while but quit, also inside/outsied air vent switch vent makes clicking noise when set to outside air
you will need to replace the blower motor as it has probably siezed going by the squealing noise you say you heard.i`m assuming this has more than 3 speeds for the fan motor.if it wasn`t working on one speed then you probably have a bad blower motor resistor that will need to be replaced as well so you will have all fan speeds.this is located in the air duct housing near the blower motor and will have about 6 wires on it.some of these on under the hood on the firewall anywhere from the passenger side to the center of the firewall.not sure about the vent switch.if the vent switch is moving the doors and you hear a clicking then you may have a vent door problem that the door pivot is worn.
Nov 01, 2013 | 2006 Pontiac G6
My heat is not working at all! When I turn the fan on I hear a clicking under the glove box. I was told that it may be the fan that is makeing the noise. What do you think?
If your fan is running as normal, then I doubt it's that. Sounds more like the blend/air door may be stuck. Here's a picture from a 99 I had to replace blower motor on. Look to left of blower motor in housing you will see the door I'm talking about. It's electrically controlled by motor attached to bottom of housing. Put your finger on that motor to see if you feel it clicking when you hear that noise. You may be smart to remove bottom part of housing(ducting) to access it, and try to free it up by hand, or remove electric motor and try to rotate shaft to see if it's free first. If it does move freely, then I'd replace the motor. If not free, then remove housing as I said and see if you can get it freed up by hand.motor1258_4.jpg
Jan 06, 2011 | 1998 Plymouth Grand Voyager
When the blu ray disc starts the player makes a clicking noise
It may be the pladder motor disc that the dvd sits on, you might be able to reset the pladder disc up a notch so it does not hit the housing, failing that suspect a bad pladder motor.
Dec 28, 2010 | LG BD370 BLU RAY PLAYER
Jcb electric mower just makes clicking noise wont start
some of these mowers have reset buttons on the motor---it works like a circuit breaker---access the motor housing to check for a button
May 10, 2010 | Acer Lawn Mower
Drains but will not spin an makes a clicking noise
Sounds like the coupling between the motor and the transmission is bad. Remove the motor and install the coupling. Put the motor back on. Should be ready to go
Jul 14, 2009 | Whirlpool LSR7333 Top Load Washer
Kenmore dryer stopped running
Hi, I can determine a motor bad by the noise. Does it hum while holding the start button or is it a grinding deep sound? It can sound like the motor starts slow but once it gets going, it is ok. Sometimes the house lights will dim when the motor statrs going bad.
Let me know if I can help you further.
Vic
Jul 02, 2009 | Dryers
Showcase freezer fan motor makes constant clicking noise
Is the noise clicking consistantly?or just on again off again?Yes there may be a faulty motor.Try removing the wires and tape them up then run the unit if there is still noise need more info .And to let you know yes they can be made into a low quality air compressor:) hope i helped :)
May 11, 2009 | Frigidaire FRS26R4A Side by Side...
Honda Civic heater / blower noise.
you need to remove your glove box assy.(beleave only 2 screws and pivot clips) make sure its not anything from glove box that has slipped behind. once box is out uf way you can access easier the blower motor assy. it actually attaches into blower box from bottom side. when looking at you will find three screw/bolts fastening motor to casing. remove those and then slowly lower motor and fan cage(attached to motor shaft) out from housing. sometimes it takes a little convincing to come out but not real tough. once out you most likely find the object causing noise in fan cage or resting up on lip area of housing unit. once found install in reverse order. let me know if this helps or if we need to dig a little deeper into! good luck!
joel
Feb 02, 2009 | 1999 Honda Civic
Boston Harbor CF78125 Ceiling Fan Logo
22 people viewed this question
Top Boston Harbor Dryers Experts
Dan Webster
Dan Webster
Are you a Boston Harbor Dryer Expert? Answer questions, earn points and help others
