Candy grand o plus
Machine won't empty or spin and lights flashing but don't know why
SOURCE: candy go482 washer won't spin
I ahve Exactly the same problem, Also bought from Cometand also had 2 engineers out.
Posted on Jun 25, 2009
SOURCE: stop light flashing
i have a candy activa cm1 146. no matter what i do the stop light is always flashing. Ive emptied the machine, turned it off at the mains, checked the waste pipe and currently trying to empty the filter, whilst the light is flashing it will not work on any programs???
Posted on Jul 28, 2009
SOURCE: could you tell me why my candy go 482 washing
could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
Posted on Dec 28, 2009
SOURCE: Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Posted on Jan 04, 2010
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
Hi, I have a Candy Grand comfort which has just stopped working. the power is there lights on but when I turn the dial it clicks as if to start but nothing happens. Thanks in advance.
Could be the door interlock or simply there is no water entering the machine. Check water supply and also the vales inside the machine . the solenoids should buzz nd hum a little if they are energised but could still be blocked ???
Dec 18, 2016 | Candy Washing Machines
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
Candy Grande o, stain vanish and 90 min light flashing
Try to find error codes on the Candy website.
Dec 20, 2013 | Washing Machines
My Kenmore H2t front load washer won't drain and
Hallo there
So it will not do what it is told. This happened to my Candy machine the other day. It was finished and I opened the door, out came water and I got 5 towels on the floor to dry up the water. Closed the door again and put empty water on, it emptied the water, stopped the machine and put spin on and it made it.
My experience ,learned the hard way, to wait long enough after the machine stops as well as between changing programs.
I this will be of some use to you.
Kolbrun
Apr 15, 2012 | Kenmore Washing Machines
Lg washing machine suddenly stop during washing
It would help to know at what stage the machine stops, however, lete me take a blind guess that it stops just before the spin cycle. If I'm guessing wrong, please tell us when the machine stops and if it displays an error code or any flashing lights (Please note WHICH lights flash and the number of times they flash, as this is an error code that will help pin the problem down).
If I'm right, then........
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 05, 2011 | LG Washing Machines
Could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
Dec 10, 2009 | Candy Washing Machines
Candy go482 washer won't spin
Apr 08, 2009 | Candy Washing Machines
Stop light flashing
Dec 16, 2007 | Candy CN146 Front Load Washer
Candy CN146
0I have a candy intergraded washine machine ,could you tell me where the filter is please as the wash finish but still has water in, I put the cycle on to the water discharge and it emptys,then i put it onto a spin which works fine. But i need to know the problem
Nov 01, 2006 | Candy CN146 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
