Question about Electrolux EDW5505ESS Built-in Dishwasher
My electrolux dishwasher will not start and no lights on panel
The panel seems to be dead and how to get in to it to check this. Can I remove it myself and buy a new part?
  • Official Brand Answer
  • 4,342 Answers
Good Morning Friend,
I understand that your Electrolux dishwasher, model# EDW5505ESS, will not start and the control panel seems to be dead. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 20-30 minutes. Once power is restored, if the panel is still not lighting up, I suggest contacting your local authorized technician. I do not suggest trying to repair it yourself. There could be something other than the panel, which is causing the dishwasher to seem dead. The technicians will be able to diagnose your appliance and determine what is causing the panel to not light up. Hope this is helpful.
-Best Regards-
WP
Posted on May 21, 2014
muttandjeff
  • 359 Answers
SOURCE: Nearly new Electrolux dishwasher - DEAD
2 THINGS COME TO MINE EASY CHECKS , MAKE SURE THE DOOR IS CLOSING PROPERLY AND THE DOOR SWITCH IS MAKING UP WELL AND CHECK TO MAKE SURE THAT YOU HAVE 110VOLTS LEAVING THE BREAKER AND @ THE DISHWASHER CONNECTION IF IT HAS A RECEPTACLE ON THE DISHWASHER END TRY TO PLUG IN ANOTHER DEVICE SUCH AS A DRILL OR SAW OR OTHER APP, TO SEE IF IT WILL RUN THIS IS A BETTER CK THAN A METER BECAUSE IT PROVES IT IS PASSING CURRENT AS WELL AS VOLTAGE , METERS ARE NONE LOAD DEVICES AND CAN FOOL YOU
Posted on Jan 10, 2009
  • 15 Answers
SOURCE: Panel not working on Electrolux Dishwasher
CONTACT ELECTROLUX. YOU EITHER HAVE A FAULTY TOUCH PAD OR A BAD RIBBON CONNECTION.
Posted on Apr 07, 2009
tattootech2
  • 72 Answers
SOURCE: All the light on my new, Electrolux dishwasher are
Remove the kickplate at the bottom of your dishwasher and see what error you are getting. Likely a leak error.Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Posted on Apr 07, 2010
SOURCE: Electrolux ewdw6505gs model dishwasher commd panel does not power
Read publication 5995509477 of Electrolux name factory Parts Catalog. You will see the POS NO 12 Part no 7154671401 name Latch Assembly, door w/shield. This relay stay open. a little bit of WD-40 and he working correctly.
Posted on Oct 28, 2010
  • 195 Answers
SOURCE: Electrolux Dishwasher no lights on panel
Check circut braker first then door latch , so are you saying no power at all at the unit ?
Posted on Dec 08, 2011
Elctrolux dishwasher won't start, display won't light. Any suggestions?
I understand your Electrolux dishwasher, model# EWDW6505GS, seems like it is not receiving power to the control panel. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. If you are still not receiving any lights, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing your control panel to not have power.. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Electrolux EWDW6505GS Fully Integrated...
Electrolux dishwasher leak detector light
This was a good answer. It reset the error. But once we started the washer up again it threw the same error. Next step, remove it from the cabinet and check for leaks.
Apr 10, 2014 | Electrolux 24 in. EDW5500DSS Stainless...
Electrolux dishwasher not completing wash cycle and all lights flashing on door control panel and the 'wash pump' error light behind the lower kick space panel was flashing.
Good Morning friend, thanks for your post!
After researching the issue you are having with your Electrolux dishwasher it is possible that resetting your appliance may help. I would disconnect power from your dishwasher by unplugging it or flipping the household breaker for roughly ten minutes. If this does not resolve your issue I would recommend seeking assistance from a professional to properly diagnose and repair your dishwasher. -T
Jan 23, 2014 | Electrolux Dishwashers
I have a Frigidaire 1000, 1200 series. I noticed the dishwasher motor sounding louder lately while it was running. The other night I turned it on to run. Later I noticed that the three lights on the...
Check for obstructions inside in the bottom first and or the pump might be clogged. If it's not some type of obstruction or clog it is likely your motor has died or is almost dead. Start planning on replacing your dishwasher. I suggest to go with a higher end brand. Kitchenaid Superba EQ, Electrolux Wave-Touch, Bosch 800 Series for example.
Sep 10, 2013 | Frigidaire Dishwashers
Elctrolux dishwasher won't start, display won't light and it randomly beeps
Check continuity of the 4 small wires that connect to the control panel to the control board. They seem to break where they flex for the door to open and close.
Jul 25, 2012 | Electrolux EWDW6505GS Fully Integrated...
My electrolux dishwasher will not start. lights on the panel are on but will not start
What to Do When the Dishwasher Won't Start - YouTube
? 5:43
https://www.youtube.com/watch?v=L-bMqVb9kX0
Aug 15, 2013 - Uploaded by doityourselfstan
I was stressing out because we could not afford a newdishwasher .... The power come on and the unit fills with water, but then does nothing.
Electrolux® Dishwashers - ElectroluxAppliances.com‎
Adwww.electroluxappliances.com/‎rating for electroluxappliances.com
Luxurious by Design, and Featuring the 30 minute Fast-Wash Cycle!
Dec 04, 2011 | Electrolux EDW5505ESS Built-in Dishwasher
Jan 25, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
I have an electrolux edw5505eps dishwasher. The control panel start button does not function, the delay button does noy cycle thru the delay time. Does the panel need to be replaced?
check out my thread on a similar issue. If your power button doesn't light and delay button does not light? Is the LCD screen display anything? check out my post several really good check lists.
Nov 08, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Apr 02, 2009 | Electrolux Frigidaire Professional Series...
Electrolux EDW5505ESS Built-in Dishwasher Logo
255 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
