Question about John Deere Garden
How do i change fuel filter in an 14sz push mower
How do I change fuel filter
  • 41 Answers
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Posted on Aug 04, 2009
  • 8 Answers
SOURCE: lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
Posted on May 01, 2010
  • 468 Answers
SOURCE: Push lawn mower will start but won't stay started.
the way it sounds then, is the fuel metering hole in the carburetor bowl needs cleaned out. You clamp the fuel line, remove the nut off the bottom of the carburetor bowl, and clean out the passages in that nut. This should allow proper fuel flow, and let your engine fun full time.
Posted on Jun 08, 2010
01fordeb
  • 1033 Answers
SOURCE: push mower runs, starves, recovers, repeats
Sounds to be the float and needle needs replaced. The float raises the needle to let gas through the carb. If the float isn't working properly the carb starve for gas. If replacing the float, be sure to clean the carb to.
Posted on Jun 16, 2010
Testimonial: "Thanks, all. "
  • 4 Answers
SOURCE: cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Posted on Aug 10, 2012
Testimonial: "I'll try this solution tomorrow. thank you for the help"
Why does a transmission on a self propelled john deere 14SZ mower ,18yr old, squeal?
Is it the transmission or is it the drive belt slipping.
That will make a squealing noise as well.
Is the fluid up where it should be?
Sep 28, 2014 | Garden
My briggs and stratton 550e push mower starts and
If your using Ethanol Fuel... This goes for All yard equip. Weed wackers,blowers,chain, etc. Change fuel lines to ethanol safe. change fuel filter, push bulbs, (ethanol fuel destroys these making them soft / shrink and close up). Mowers, remove carb. bowl under carb. 1 bolt spray carb cleaner around, under and in bowl (may have to r&r needle if sticking) clean / replace air filters and possibly spark plug....All maintenance items.(Change Oil) If this doesn't do it.... there's more, this is the simplest start........
Aug 26, 2014 | Garden
Throttle on 14SZ not working, stays in low
CABLE STRETCHED..OR THERE WILL BE AN ADJUSTMENT TO CABLE SOMEWHERE...LOOK! SOMETIMES ADJUSTER IS AT LEVER..LIKE AN AUTO HOOD CABLE
Sep 09, 2012 | John Deere Garden
My troybilt 675 series push mower stalls out when pushing up a slight incline how do i fix this please?
clean and check carb may need a rebuild also check in tank filter and fuel lines
Nov 12, 2017 | Briggs & Stratton Garden
How do I change the fuel filter on a yard Machine 6 Hp mower
A lot of the smaller machines do not have fuel filters, unless you put one in line yourself. Some will have a small screen in side to fuel tank or if you separate the tank from carb you might find a filter, most likely your machine is not equipped with a filter. Good Luck...
Aug 16, 2011 | Mtd 22" Yard Machine Push Mower
Push lawn mower will start but won't stay started. Changed spark plug and filter. Does it have a fuel filter? Or what should I do next?
Jun 08, 2010 | Poulan "Poulan" Push Mower
Lawn mower wont start. changed air filter, spark
May 01, 2010 | Poulan Garden
Aug 04, 2009 | Garden
Yard machine 21'' push mower runs 2 to 3 seconds cuts off.
Tip the mower up on it's side with the dipstick tube on the down side and collect it in a suitable container. The gas you can do the same. When I drain old fuel, I mix it with a lot of fresh fuel and a bottle of dry gas then run it in my car.
Apr 23, 2009 | Mtd 22" Yard Machine Push Mower
Yard Machine MTD push lawn mower won't start
Sounds like you need a complete tuneup. Start with the carb. then clean all coil contacts, air filter and this will start you in the right direction. Good luck.
Mar 24, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
