Whenever I plug the pump in the display comes up with e05, I don't know what this means and I'm not sure what I need to do to get the pump working again and to clear the error.
SOURCE: error message
this problem is related to the total counter,it may be disconnected or you may check connector 12 on the main cpu if you feel you are experienced enough regards lloyd
SOURCE: What does SF mean on pool and spa pumps?
SF stands for Service Factor. It has to do with how much overload your motor can handle without damage. Here is some information about it:
http://www.engineeringtoolbox.com/service-factor-d_735.html
You should not be feeling any "trickle" of electricity. You are correct...it is NOT SAFE! I would definitely have another qualified electrician check your wiring out.
Thanks for using Fixya.
I happen to work for Rome Industries and can help you out. The "LP" code on your control board represents "Low Pressure". This is referring to the refrigerant pressure within the unit. The unit is equipped with a low pressure safety switch that when activated shuts the unit down. This could be caused by a refrigeration leak, a stuck thermal expansion valve, or even a faulty pressure switch. If you live within the state of Florida contact Rome Industries and you will receive a free of charge service call including parts and labor as long as your unit is under warranty. If your outside of the state please contact your dealer to handle the claim. Have a good day.
SOURCE: what does error code E05-11 mean?
switch off then on, pull top cassette out slightly. this will provide a temporary solution. a service technician will need to see the machine.
SOURCE: Heat pump will not start
Could be a firmware issue and require a new mother board. Unfortunately, you probably have done all you can on your own. Time to call the local HVAC service person...
