Wm f1 wear can i get it fix
My Hotpoint WM 19 First Edition Door will not open how do I fix it
There will be a release lever under the machine and near the front. Only do this with the power plug removed.
Mar 14, 2012 | Hotpoint Washing Machines
OE for LG WM-0532HW
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Jan 31, 2010 | LG WM-0532HW Front Load Washer
CODE f1 FLASHES , I unplugged the oven for 1 hour and stil comes back with the f1 and beeps
f1 code on most ranges are erc failure. only way to fix is to replace the oven control board
Nov 05, 2009 | Kitchen Ranges
Sony Walkman cassette player/recorder will not rewind the tape
Fat chance to repair yourself! we repair that WmD6c but very hard to do!
Feb 23, 2009 | Sony Walkman WM-D6C Personal Cassette...
Fixing lg whasher
??? not enough information, what do you mean by this? the clothes are still wet when they come out the machine does not spin at all?
the machines have a set time to drain before they spin usually three minutes if the water has not dropped below a level before the set time the machine will stop, check the drain
Clothes begin to get wetter than before? how old is the machine motor brushes usually last 2-3 years depending on usage when they wear down the parts of the program that put the most power through the brushes can fail first (Spin)
Nov 21, 2008 | LG WM-2277HW Front Load Washer
LG washer comes on then shuts off
I need a little more info, does it make any sounds b4 it shuts off is there any codes F1 or anything like that. Does the water start to fill? Does it start to rotate or anything at all b4 it shuts off?
Oct 27, 2008 | LG WM-2277HW Front Load Washer
LG WM 12230FB WASHING MACHINE
the belt which s at presently fixed is not of proper size change the belt and try it. the drum will run properly
Jul 06, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer not working with ce showing
CE is an error stating that you have a problem with you board or possibly the stator on your unit. Either way your going to need service. You can ohm out your stator to see if it is the problem.
Check the back harness, maybe it has come loose, remove the back panel and it is the blue connector.
Sgt 48
Jun 07, 2008 | LG WM-2277HW Front Load Washer
 Grubhead
Grubhead
