Question about Crystal Care Aboveground Pool Maintenance Kit
Don't understand how to measure - Crystal Care Aboveground Pool Maintenance Kit
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Crystal Care Master
  • 1,448 Answers
Go to google look up pool chemistry they will give you charts on adding chemicals
Posted on Aug 25, 2014
A friend gave me an optical tape measure ranging 600, I've never used one and don't understand quite what it's for or how. Not sure if it's for surveying or how to even go about using it.
It's for general purpose measurements. Usually, point it at a wall and press the measure button. It will indicate the distance from where you're standing to the wall. With a little practice, you'll be an expert and won't need to use a tape measure for the longer distances.
Oct 17, 2016 | Measuring Tools & Sensors
What is oil capacity of unidentified chainsaw?
I would suggest draining the oil sump and measuring it as you re-fill it. Use measuring devices with oz or ml increments. I don't see your question as relevant though. When a guy is cutting wood, you just fill up the oil and gas and cut. There's no measuring required. Of course I understand there is probably another reason for the question as posted...
Oct 01, 2015 | Garden
How do you use CHASHOTAO to calculate the Hypotinus given the adjasent length and opposite angle
You should be aware that the adjective adjacent has no absolute meaning. It is relative to the angle you are considering.
Let some angle A in a right triangle. Let H be the measure of the hypotenuse. Do not confuse it with some height.
cos(A)=(measure of leg adjacent to A)/H
H= (measure of leg adjacent to A) / cos(A)
However what you call the opposite angle (the other angle I presume), is the complementary of of angle A. Call it angle B
In terms of that second angle
H=(measure of leg adjacent to A)/ sin(B)
What is adjacent to angle A is opposite to the complementary of A.
I think you should work a little more on the meaning of the words adjacent and opposite until you understand that they are relative concepts. They mean nothing until you spell out what angle you are looking at. Without proper understanding of these two concepts you will not be able to use correctly that mnemonic device which you have mangled (BTW)
I do not know it what language you have transcribed the mnemonic , but in English the device is called SOH- CAH-TOA
SOH means: To calculate the Sine of an angle divide the measure of the leg Opposite to the angle by the measure of the Hypotenuse.
CAH means: To calculate the Cosine of an angle divide the measure of the side Adjacent to the angle by the measure of the Hypotenuse.
TOA means: To calculate the Tangent of an angle divide the measure of the side Opposite to the angle by the measure of the side Adjacent to the angle.
Dec 10, 2013 | Computers & Internet
Kawasaki zx 400 d
First suggestion, read what you post to make sure we can understand the question.
May 25, 2013 | 1989 kawasaki ZX 400
Don't know how but langauage has changed from English and don't know how to change it back as all text is in language I don't understand.
use this http://translate.google.com/ it will automatically detect language ....then go to phone settings and language settings and change it ...
or better factory reset your phone check ur manual for that.
Oct 22, 2011 | LG Prada KE850 Cellular Phone
I have a nisssan sentra 2002 with code p0031 what is this?
this obd2 trouble code table can help you understand the menaing of code, and for p0031, try:
check for 12 volts at the heater circuit feed (hint: unplug the sensor and check at the wiring connector to do this measurement).
check the ground circuit for continuity.
measure the resistance of the heater circuit (done on the sensor itself).
measure the resistance and voltage of the wiring.
Sep 02, 2011 | 2007 Nissan Versa 1.8 Sl Hatchback
I purchased my subs in a bandpass box. The whole thing was preassembled. It was about 5 years ago that I bought my system. I had it in my vehicle for about a year, then had it in storage for the...
Chances are these are 12" in size (measure the diameter of the speaker - from one side to the next).
Usually, if subs come with a bandpass box, the box would have been measured for the correct air space.
However, if you want to know how to design your own enclosure then I will direct you to this web page, which can give you some basic understanding:
http://www.bcae1.com/spboxnew2.htm
Hope this helps...
"Please rate this solution"
Aug 28, 2011 | Phoenix Gold Octane-R 12/12d Car Subwoofer
New alternator puts out 11.7 volts. Changed it for another which is also putting out 11.7 volts. Changed double female connector; no help.
First, make sure that the alternator is properly grounded.
Second, with what are you measuring it? I have a couple of cheap ($10-$30) Chinese-made digital voltmeters around my garage that I know for a fact don't measure DC voltage accurately. They tell me a battery has 11 volts, and I dig out my trusty 40-year-old analog voltmeter with a cracked face and it accurately reports 12.6 volts as it should. Also, the digital meters also drift like crazy when I try to measure resistance with them.
I don't know why, but it seems that you cannot buy a reliable voltmeter for less than $125 any more.
May 15, 2011 | Chevrolet R10 Cars & Trucks
Each diagonal of a square measures 1 inch. if the diagonals bisect each other and segments formed measure x/3 and 1 - x/6. what are the exact measures of the segments Enter Problem: Help Math...
If the diangonal of a square is 1, either side opposite the diagonal is equal to the sin of 45 degrees. sin 45=.70710678. The segments formed by the bisection of the diagonals would be one half the length of the diagonal which would be .5 x 1 = .5. Or you could take the sin of .70710678x.70710678=.5 for the bisectors.
(if I understand what you are asking.)
Oct 12, 2009 | Hawk GEOMETRIC DRAWING TOOLS 5-PIECE SET
I put in a DVD and it says NO DISC.
1st, I think the term 'Expert' is used too loosely here, at least for me. LOL. I just had the pleasure of fixing an IDM-1731 with a 'No Disc' error. It just so happens that calibrating the drive helped me out.
For any of you that feel like taking a risk & opening up your player, I urge caution when handling the optical lens. There are 2 pots located above the ribbon on the end that connects to the lens to the left. The 1 on left I touched to the right & that helped me out. I'm thinking that the vibration caused the player to get out of whack as time goes on.
After getting the player to work, I took measurements with my multimeter. The left pot measures 3.06 k ohms & the right measures .965 k ohms. I hope this helps others out as it did for me.
Nov 23, 2006 | Initial IDM-1731 Portable DVD Player with...
Crystal Care Aboveground Pool Maintenance Kit Logo
312 people viewed this question
Top Crystal Care Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Crystal Care Pool and Spa Expert? Answer questions, earn points and help others
