Question about Brother BRTPT65 PT-65 Label Maker Printer
Cartridge is fine, the label come out blank - Brother BRTPT65 PT-65 Label Maker Printer
Dear sirs , i have a epson stylus r230 photo printer,i am getting blank prints from my r230, its has new replaced print head, new data cables and i even tested labeled F1 and it is near the 3 tall blue...
take all cartridges out shut off then turn on make surethere is no obstructions where cartridges go replace them one at a time i found a piece of tape on mine would not print black and white removed it now it is fine
Jan 23, 2015 | Epson STYLUS R230 InkJet Photo Printer
Label is printed fine but each printed label print blank line before label print
To isolate problem run a test label from printer.Does the same thing happen? If so it is a printer problem.If not the problem is in the document itself.
Apr 24, 2014 | Zebra LP 2844 Thermal Printer
Label maker is printing blank labels when text has been typed in. Need fixed as soon as possible.
1st of all did you check and made sure the cartridge is working fine?
If not try to take the cartridge our of the printer and inspect if the tape is cut, if found to be cut replace it imdly. Take help of the user manual for replacement of the cartridge etc.,
Jul 14, 2011 | Brother P-Touch 1180 Label Printer
I just purchased new cartridges, but there's no print on the labe
It was the batteries. I bought new ones and it works now. Good advice. Thanks.
Nov 18, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Blank paper
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Epson c84 printer not printing after installing new ink cartidges
Hi, Linda
You may buy cartriges of different producers.
Depending on producer on them can be or be not special yellow detachable labels.
These are an yellow labels must be removed from them. Then put cartridges back. And try to clean head 4-5 times. And check nozzle test.
Good luck.
Mar 06, 2009 | Epson Stylus C84 InkJet Printer
Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
Nov 18, 2008 | Dell A960 All-In-One InkJet Printer
Printing blank labels
I am having the same problem! Printing blank labels. Don't know what's wrong now. It was working fine yesterday.
Jul 22, 2008 | Dymo LabelWriter 400 Thermal Printer
Brother BRTPT65 PT-65 Label Maker Printer Logo
71 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
