Question about Ovens
Ge built in convection oven model jctp18
Need cut-out specs
hbsurfdawg
  • 95 Answers
SOURCE: heating element will not heat
With all that you said, I would suspect an open or faulty element. It is pretty much the most obvious solution.
If you have any electronically ability and you are going to open the oven, use an ohm or resistance meter, check the amount of ohms and use the upper element as a reference for the correct reading.
The element will either read open or good. You can use a light tester also and if the light lights between the two connectors of the elements, then it is ok and look elsewhere.
E
Posted on Mar 02, 2009
jmgldsmth
  • 1889 Answers
SOURCE: GE Gas Built-in Oven model JGRP17B Door Replacement
pull out the bottom drawer you will find a plate on the left side pillar of the drawer opening the model # and, serial # is there this is all that is needed to order a new door glass
Posted on Apr 22, 2009
SOURCE: Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Posted on Jun 18, 2009
milten1
  • 1304 Answers
SOURCE: ge profile oven/convection oven humming when on convection settin
ensure that your convection fan is turning
a hum on this model usualy means that the convection motor can seize up a bit
sometimes all you need to do is redjust the fan blade
Posted on Oct 13, 2009
SOURCE: I need the squematic wiring GE 24" Built-In Gas Oven
I have the same problem -- did you ever get this question answered?
Posted on Jun 14, 2010
I have a GE Monogram Built-in Convection Wall Oven (model no. ZEK737WP3WG) and the heating elements have stopped working. The electrical power is working, and the control panel, light, convection fan...
It is possible that a relay on the control board is bad. GE has a relay in the common circuit to the bake and broil element. this has been a problem in a few ovens I have repaired. Check for this it is usually an orange relay on the board.
Apr 27, 2014 | GE Ovens
How to install GE JKP35DPBB 27" Double Electric
The specs for this double oven give a rating of 5.1kW at 208V so it needs a 30 Amp circuit breaker. This assumes that the oven is the only appliance on the circuit. So you should be able to use the same circuit breaker.
A bigger consideration is that the opening for the double oven needs to be larger than that of the single oven. If the opening does not have a solid bottom, it must be able to support a heavier load. The runners and braces under a single oven has to support 200 pounds (91 kg). A double oven must have braces and runners designed to hold 375 pounds (171 kg).
Also check if your household uses aluminum wiring. The new oven has copper and problems will occur at the interface if you do not use the appropriate precautions. (Products designed for mating copper and aluminum are available - follow the directions).
I hope this helps.
(btw: you can find the User's Guide and Installation manual for the double oven at GE's website: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JKP35DPBB . See the section Literature and Manuals on the left hand side of the page below the picture of the oven.)
Oct 29, 2010 | GE 27" Built-In Double Electric Convection...
Ge profile oven/convection oven humming when on convection settin
Oct 13, 2009 | Ovens
I was cleaning my GE profile convection oven and after the 3 hour cycle, an error message F 1 started flashing, and the oven started beeping.
We frequently see this symptom due to a failure in the electronic range control (ERC). We repair a lot of these.
- www.fixyourboard.com
Jul 24, 2009 | GE 30" Built-In Single Electric Convection...
Jun 18, 2009 | GE Profile JT912 Electric Single Oven
I need an installation manual for a built in dual GE oven JKP4. how do I install it without burning the house down
Go to this link:
http://genet.geappliances.com/DocSearch/Dispatcher
They have Use, Care, Specs and installation manuals for many of the JKP4 models.
Good luck and I hope it works for you.
lrminer
Jun 11, 2009 | GE Ovens
Apr 21, 2009 | Ovens
Ovens Logo
26 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
