Question about Digital Audio 2, CHANNEL 600 WATTS HIGH POWER CLASS A/B AMPLIFIER DA2200W Car Audio Amplifier
Fuse melts when turned up all the way - Digital Audio 2, CHANNEL 600 WATTS HIGH POWER CLASS A/B AMPLIFIER DA2200W Car Audio Amplifier
  • 25 Answers
Speakers are overdriving the amplifier you need a higher wattage.
Posted on Jun 24, 2009
2004 kia a/c fuse melted now i have no a/c and cant replace fuse
Hey Dale, a melting fuse is a serious problem..For a fuse to melt, there is a LOT of current, ABOVE what that particular system is designed to carry.. in an ideal situation, ; the fuse would have blown and not melted..(did you put in a higher rated fuse to try and over ride the issue???)..ooppsss...
Dale, you have an issue that need a QUALIFIED PROFESSIONAL to repair...
Jul 09, 2017 | Kia Cars & Trucks
My 1998 zero turn encore mower is dead
Cause: If the fuse itself has not blown but the fuse holder has melted, it indicates that the equipment is not drawing excessive current, rather that the fuse holder was making poor contact with the fuse. Heating in an electrical circuit is always caused by current flowing through a resistance. See if can find some electrical contact cleaner and clean. I would go a box auto parts store and see if they have it.--Autozone O'Reilly Auto Parts
Jul 02, 2017 | Garden
No brake light .turn signals or blinkers everything else fine whats up
Most Honda bikes of the 1980's had small fuse boxes with 3-4 fuses at the most. Usually 1 for ignition and charging, 1 for Headlight Only, and 1 for All other lights. Overheated and even melted fuse blocks are commonplace in these years due to high current draw and the plastic block which melts and distorts over time, breaking the circuit to the lights. Replace all 3 or 4 circuits of the old fuse block with modern in-line blade-type fuses and this will never happen again. (If the fuses are all good, and the plastic box is not melted or burnt, you may have a bad Ignition Switch, but this is rare)
Sep 30, 2012 | 1986 Honda CB 700 SC Nighthawk
My dryer will not turn on, there is current to electric plug.
The thermal fuse is located on the back side of the dryer. If you see lint built up that fuse can be melted. If it is melted then the motor won't run because that fuse is in the same circuit as the door switch. So if the fuse is good look for a bad door switch.
Roper dryer tuneup
Service manual and more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 11, 2011 | Roper REX5635E Dryer
2000 Kawasaki KLR 650 fuse box melting
Hi, Dnicholl708 you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away from the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://www.klr650.net/forums/showthread.php?t=51945
Kawasaki KLR 650 fuse box melting Google Search
Kawasaki KLR650 1987 2002 Workshop Service Manual Repair Download Manuals... $15
OEM Parts for Kawasaki
2000 Kawasaki KLR650 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 26, 2011 | 2000 kawasaki KLR 650
What is wrong with my 1000w sony xplod amp?
need repairs on the inside usually when u see that fuse melt something else probably melted on the inside. something is grounding out the amp on the inside . get it checked
Jun 05, 2010 | Car Audio & Video
I have a 82 gl 1100 goldwing. The previous owner
The fuse on the starter solenoid is the main fuse for the bike. If that fuse was removed and replaced with a wire, you could melt down the entire harness or even burn up the cycle. The short that was popping the fuse has probably melted part of the harness or popped fuses in another part of the bike. Start checking in the main fuse box in the fake tank for shorts. Also check the solenoid with the main fuse for melt down, good luck.
Apr 28, 2010 | 1982 Honda GL 1100 Gold Wing
Fan fuse keeps burning out
I would think the fan motor is drawing too much current, causing the fuse housing to melt.
Apr 09, 2009 | 2002 Volkswagen Jetta TDI
Fire behind dash from horn fuse
fire melted other wires blowing more fuses or relays
Mar 15, 2009 | 1989 Chevrolet S-10 Blazer
Amp heats up quickly, melts fuses and shut down after a while
It sounds like the power cable you have may be too small. If you're using an 8 gauge for both the power and the ground, try switching to a 4 gauge for both.
Aug 18, 2006 | Alpine MRV-F357 Car Audio Amplifier
Digital Audio 2, CHANNEL 600 WATTS HIGH POWER CLASS A/B AMPLIFIER DA2200W Car Audio Amplifier Logo
54 people viewed this question
Top Digital Audio Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Digital Audio Car Audio and Video Expert? Answer questions, earn points and help others
