Question about MicroBoards Orbit (ORB-4201-01) Burner
I have an older computer which uses a D-sub input on the mouse and the mouse has gone bad and I can't find a mouse with a D-sub connector so I am going to rewire a new mouse to the D-sub, Question is does anyone know what pins to use on the D-sub? Please reply to williams4088@bellsouth.net. Thanks for your help.
    President:
  • 1,996 Answers
Have you checked the local thrift stores? Or local computer techs, who often recycle older systems? Or an adapter cable like this one?
Anyway, here, here, and heres a pinout for ps2-dsub connectors. Here is dsub pinout.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 23, 2009
My computer mouse and keyboard not functioning well. I replace the keyboard but only last a month.
Hi jhunix,
I'm going to need even more information; The devices that use PS2 connections, which device is it, and how many of those devices do you have?
One thing that might be a problem, if the issue you see is intermittent, I would check the PS2 connector and see if the pins are bent or broken. PS2 connector pins sometimes will bend or break and this can cause some connection issues if not completely stop the keyboard/mouse from working... Also given the age of your PC the PS2 port may just be bad, but this is not a fatal injury to a computer.
Replacing the Keyboard and Mouse with a standard USB keyboard and mouse, should resolve all of your issues.
PS2 is an older technology that keyboards and mice used to run on; Now however USB connections are used.
Further more, if this an HP Desktop with 2 USB ports on the front, and 4 USB ports on the back, you will want to avoid using the 2 USB ports on the front, especially on older HP and Dell Desktops, the reason is the power supplies often do not have enough power to run multiple USB devices on the front USB ports.
The back ports should be fine regardless of the number of devices.
Hope this helps.
Dec 10, 2013 | Computers & Internet
Philips sw3440/37 audio inputs D-sub 15 connector pinout
this is what i have on mine i used a 3.5 mm jack as an INPUT and i also have a set of female RCAs next i will be replaceing the plugs for speakers and putting standard speaker terminals
Jul 20, 2012 | Philips Audio Players & Recorders
A blue display box continually pops up with Input Select D sub DVI. I am thinking it is something to do with the monitor. What is wrong?
This monitor has two types of video inputs, a 15 pin VGA D-sub connector and a DVI connector.
If the video card has a 15 pin D-Sub then connect the video cable to the 15 pin D-Sub connector on the monitor.
If the video connectors are DVI then connect the video card and monitor with a DVI video cable.
You will also need to configure the monitor for either the D-Sub or DVI video input.
Aug 03, 2011 | BenQ FP91G+ 19" LCD Monitor
I have an older computer the old mouse had a different connector I just purchased a replacement ge 99918 can I hook up the mouse in any unused USB port.
If the mouse you bought is a USB mouse, then yes you can use any USB port on your computer you want to use.
Jun 20, 2011 | Computers & Internet
I have an older JBL TLX PS10 sub woofer but hardly used. I get a green light when plugged in. However, the speak makes a loud continuous noise when I plug in the Y connector to the low level input. It...
Just touch your fingertip to the input connector on the sub -- similar noise? That would be its amp picking up the hum of the room through your antenna-like body. IF that is the same noise, you need to make sure your input cable is shielded and connected at both ends BEFORE applying power to the electronics at either end.
Be mindful of electronic noise sources such as track lighting, UV lights, motors, TV's, etc, and route the signal and power cables well away from them.
Try reversing the orientation of the AC plug at the sub and see if that helps out.
Feb 10, 2011 | JBL TLX PS10 Speaker
TheGE wireless Mouse seems to have batteries charged and functioning. The small USB connector seems to bethe problem. I think it used to light u7p when inserted into the usb slot but no longer. I have...
If it used to light up and now doesn't, it's probably gone bad. You did the correct thing in testing it on another computer.
If it has a little "connect" button on it, push that button.
Also push the "connect" buttons on the mouse and keyboard.
See if that helps.
Oct 08, 2010 | GE Wireless Optical Mouse
I have just got a Toshiba 37AV502R flat screen tv. I want to connect the digital audio output (optical) to my older 5.1 speaker system. The input on the sub woofer is a 15 pin VGA... I can't seem to find a...
Is this sub a Bose. The only reason you would see a VGA type connector on a sub is if it is dedicated to somthing else such as Bose 3-2-1 system. This is not a standard VGA input and can only be connected the the dedicated head unit. I need more info on the sub. Brand and model. Ther should be an analog audio input on the sub. This will be sufficient.
Oct 31, 2009 | Toshiba 37AV502R 37 in. LCD TV
No Sound from Jamo E6 Sub
More likely there is a bad solder connection or a bad connector contact inside the unit, could also be a blown or dried up electrolytic capacitor.
Check the line signal input plugs, if they are soldered directly to the board then check the solder around the pins - if it has circular cracks, you need to resolder the pins.
Also check any other components on the board for such cracks on the pins, including internal connectors, disconnect, clean the pins if necessary and reconnect them.
If any electrolytic capacitors have a bulged top, they are blown and need to be replaced.
It could as well be something else, but your description suggests either a fault at the input connectors or some trouble with the input signal level sensing circuitry (no signal to the sensing circuit may be caused by connectors, no response from the sensing circuit may be caused by bad capacitors or other faulty components in or around that section).
Hope you can find out what it is and fix it...
regards
3rq8 (Triarcuate)
Sep 04, 2009 | Jamo E6SUB Subwoofer
Keyboard wont work
ok I don't really have enough info on this question but im pretty confident i can help you.
it sounds like your brother has a desktop computer and its a bit older. so since he does not have usb ports on it it has a pin connector called ps2 its located next to the mouse connector.
all you have to do is go to a store that carries OLDER keyboards maybe even a used keyboard just plug it up (while pc is off) and that should resolve your issue :)
Apr 10, 2009 | Dell OptiPlex GX270 PC Desktop
MicroBoards Orbit (ORB-4201-01) Burner Logo
57 people viewed this question
Top MicroBoards Computers & Internet Experts
Marvin
Marvin
 Grubhead
Grubhead
 Russ Hill
Russ Hill
Are you a MicroBoards Computer and Internet Expert? Answer questions, earn points and help others
