Question about Humax Televison & Video
Humax box will not turn on
I leave the freesat receiver on standby on low power as recommended, but will not turn on again the next day. I then have to remove the power lead from the socket to let it reboot, then it is ok
2 Suggested Answers
  • 70 Answers
SOURCE: How can I extend my humax freesat box into another
my suggestion, come out of the box with a splicer cable a small 6 inch piece is enough. Get a high quality cable splitter such of what the Cable guys would use, you can buy them at a hardware store. Note that you can get more than a 2 way splitter however the more you split the lower the quality at the other end,. Anyway you split the cable after your cable splitter 1 to the tv, and take the other one which ever room you want.
Posted on Feb 04, 2011
Testimonial: "Your explanation is very good,however I must make a final comment when I buy the materials to do the job and see how good the picture is in my conserv"
When I purchased my humax freesat box please
You'll need to contact Humax directly.
Mar 02, 2015 | Humax Televison & Video
How do i retune my Humax freesat box
Find the address and mail it back but it must be in original box
Feb 14, 2015 | Humax Televison & Video
My youview has taken over my humax channels
Put BT box into standby. This is probably due to the scart connection. Try to connect both boxes via HDMI if possible.
Aug 23, 2014 | Humax Televison & Video
Freesat box keeps freezing when you put TV guide on
Go into Factory reset, but before check if your system download is up to date, ( in menu )
Aug 10, 2014 | Humax Televison & Video
Humax Freesat was working fine then lost signal and now is not reognising postcode. We have unplugged/repluged, checked all cables (all OK) and tried to restart but as it is now not recognising postcode...
This can happen if the dish is slightly misaligned. I believe the postcode tables are read from a satellite which is about 0.3 degrees away from the Astra satellites. If your dish is slightly misaligned it may not be able to receive it correctly, also the following is the standard procedure which you've probably already been through, but I hope it helps:
1. Freesat Detection Fails / Invalid Postcode
  • Unplug the Foxsat-HDR from the mains and unplug the cable from your dish which is connected to the LNB IN
    connection.
  • Check that the "F-type" connector is firmly on the end of the cable.
  • Power on the and follow the Installation Wizard again.
2. If still not Detecting the signal or verifying postcode
  • Select NEXT through the Installation Wizard and then FINISH at the end.
  • Press the OK button to enter the SETUP menu and Select Manual Tune.
  • Select the following Transponder (11428 H 27500 A) from the list of Transponders.
  • Check that you are receiving stable levels for both Signal Strength & Signal Quality or >50%.
  • If you are not receiving sufficient Signal on this Transponder then you may require an installer to check your
    Dish Alignment, LNB, cabling, or connectors.
Nov 16, 2017 | Humax FOXAT HDR DTV Receiver
How do I update my humax box?
Hello
You have to getin to this site for a software update to your Humax Foxsat.
(http://www.humaxdigital.com/freesat)
From ite main Menu, come to "Edit Channels" window and select the third option 'Software Update" and 'OK".
# When there is no new software to update, a popup will appear
# Software updates for products will be detected using the Automatic Update option
OTA - Over the Air Software Updates will be broadcast via satellite for the product when new updates are
available. Humax reserves the right for deciding when the software updates will be released.
Follow below to ensure that you receive the OTA Software Updates when they are released:
1* You are connected to a suitable satellite dish and are receiving the all of the freesat service.
2* The signal strength and quality are at a high level; if you are experiencing problems with the signal
then please do not continue with the download.
3* The product is in Standby mode each night allowing it to detect, download, and install the updates
when broadcast
Caution:
* Please do not unplug the product from the mains during the software update procedure; this can
cause the product not to operate.
* Please do not remove the antenna cable from the dish from the product during the update as this can
Note:
* For information on the release of new software or the changes made please visit www.humaxdigital.
com/freesat.
* The download can take between 5 - 10 minutes to complete.
* During the update process you will not be able to use the product.
* During the software update scheduled recordings will not take place.
* You cannot schedule programmes during software update
OK.
Sep 18, 2011 | Humax FOXAT HDR DTV Receiver
I want to use my tevion remote to operate humax freesat box? i dont know how to use it
You will need the correct set up code to link the remote to the freesat box.
try this website http://www.xdiv.com/remotes/
Feb 18, 2011 | Televison & Video
Humax PVR9300t keeps freezing, have received instructions from Humax on resetting PVR to basics which hasn't solved the problem. Is now starting to freeze during recordings.
Apparently there is a new Humax software update which will be released on 3rd March 2010 - leave your box on standby that night & hope for the best.
There are a number of us with the same problem. Curently the only solution is to power cycle the box (turn off & on again from the switch at the back)
Nov 18, 2009 | Samsung SIRS4120R Receiver
Televison & Video Logo
26 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
