Question about Health & Beauty
Is this bed a220 or 110 volt bed? - Health & Beauty
Plug in for a 24sr tanning bed for my home
Was your furnace electric or gas? If it was electric it was probably 220 and should work (although testing with a volt meter would be a great idea)
Jun 17, 2016 | Health & Beauty
Does the pump on an Intex Bed 58627/68627 stop filling automatically?
no but it does change pitch of sound it makes as bed fills up that could fool you to thinking its stopped
Jun 26, 2014 | Intex QUICK-FILL ELECTRIC PUMP, AC 110-120...
How can I wire a 110 outlet to a 220 outlet?
If the bed is a 220 volt, you can only use a 220 volt outlet.
If the bed is 110/220 you should check the web for specs and wireing.
May 31, 2014 | Health & Beauty
1987 sca 24 series 1tanning bed manual
I have 1987 SCA-24 series 1 wolffsystems tanning bed how do I change the bulbs or where can I get owners manuel?
May 29, 2014 | Wolff Sunquest Pro 24RS 220 Volts
240 v should work right?
no, voltage is not the issue, what is the amperage you need. If you need more than you have, then you could have 2000 volts and it will not work. Also your taking AC to AC, or DC to DC. There's a big difference in what you need for each.
look up Ohms law for for the calculations needed for voltage vs amperage using one socket.
good luck
Apr 30, 2013 | Health & Beauty
How to remove and install ballast in sunquest 24 taining bed
I have a question for someone who knows about a Sunquest 24 r tanning bed? Involving bottom bulbs not lighting at all?
Feb 02, 2013 | Wolff Sunquest Pro 24RS 220 Volts
Wolff sunquest bottom lights dont turn on
There should be a cord that goes from the top of bed to the bottom section of the bed in the back of the bed. Make sure the cord is plugged in all the way and is not broken. This cord could be bad, the plugs may be bad, the cord could be missing entirely. A connection to the plugs could be burned out inside the top or bottom sections or at the main power relay.
Sep 18, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Wiring home tanning bed
If you are installing a bed in your home for the first time, you should have a trained technician to do it, or bad results can happen. Be sure the voltage is correct to the bed - very important. All local wiring codes should be followed for safety - you don't want to kill anyone or the bed.
Sep 02, 2012 | Wolff Sunquest Pro 24RS 220 Volts
2003 SUNQUEST PRO 24RS MANUAL TANNING BED
I Have a m2 24rs8 tanning bed. I loved it . I have moved it was in storage for 2 1/2 years. Moved to a new house. I hooked my bed up. the only thing it does kinda turn the fan on. what have I done wrong....It is on a 20amp bracker. Wire is 12 2 with ground. HELP PLEASE
Aug 25, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Alisun 24 bulb 26 SXB wiring diagram
Why do you need a diagram? Tell me what the bed is doing or not doing. I may be able to help.
Jul 28, 2012 | Wolff Sunvision Pro 24S Tanning Bed
Health & Beauty Logo
13 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
