How to fix Aceliner Stapler 502 to staple as an "innie" and not "outie"
brainyass
  • 242 Answers
SOURCE: Stanley TR70 Manual Stapler won't accept Arrow 1/4" staples
It sounds like you have a light duty stapler and are trying to use heavy duty staples. 1/4" refers to the length of the legs not the thickness of the actual staple. You probably just need light duty staples.
Posted on Oct 23, 2008
SOURCE: refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Posted on Dec 05, 2008
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
rowdy45176
  • 2176 Answers
SOURCE: Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Posted on Mar 15, 2009
  • 233 Answers
SOURCE: staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
Posted on May 27, 2010
HOW TO LOAD THE ace liner stapler model no. 502?
pull harder and possibly use pliers to help you hold on to it .
Jun 11, 2016 | Tools & Hardware - Others
My stapler won't wrap staples around the paper. What can I do?
Amazon.com : The Classics Staple-Free Stapler the "Paper ...
www.amazon.com/The...Staple-Free.../B000IGCUZE
Amazon.com, Inc.The Classics Staple-Free Stapler the "Paper Grip" with 5 Sheet Capacity, Kid Safe (TPG-133). by The ... Gift-wrap available. Enter your ..... It is hard to get the correct pressure on the paper--too much and it tears, not enough and won't fasten.
PaperPro Prodigy One-Finger Desktop Stapler, 25 Sheet ...
www.amazon.com/PaperPro...Stapler/.../B000GGY9L...
Amazon.com, Inc.
Rating: 4.4 - ‎399 reviews
Gift-wrap available. ... One-Finger Stapling Technology only needs one finger to stapleup to 25 sheets ... The Paper Pro Prodigy Stapler is the most distinctive, powerful non-elictric stapler available. .... This is such a great, easy to use, and quality stapler that once you use it, you won't want to use a ... A near-great stapler.
Swingline® Full-Strip Stapler, 15 Sheet Capacity ... - Staples
www.staples.com > Office Supplies > Office Basics > Staplers
Staples Inc.Stapler can easily handle up to 15 sheets of paper at a time and has ... refill this Swingline stapler with a full strip of standard office staples, so it won't run out of ...
Staples One-Touch™ Plus Desktop Flat Stack Full Strip ...
Jan 10, 2016 | Swingline 87845 Optima ® 40 Desk Stapler
I have a power shot pro stapler the power is not working how do I fix this?
This type of stapler is not supposed to close the staples. The legs remain straight after exiting the stapler.
Dec 04, 2014 | Staples Tools & Hardware - Others
Help please! I have a Paper Pro high capacity stapler that will not staple. I can open it up and put staples inside, but no staple will come out when pushed down. Oddly enough, if I put ONE staple inside...
are you using the correct size of staple?? (thickness wise) secondly check the spring is pushing as it should, also a fix to get it working is as you put the staple stack into the stapler, seperate them and see if will staple. other than that it's defective and you should purchase a new one.
Oct 30, 2013 | Staples PaperPro 1200: Heavy Duty Stapler
Can not find staples for 502 ace liner stapler ,
Hi, I found them on amazon, click here and take a look: Staples Undulated For 07020 Clipper Plier 5000 BX. I hope this was helpful. Cheers
Jan 23, 2013 | Tools & Hardware - Others
User manual for one touch stapler H60
To fix the Staple's One Touch Stapler, you must pull the stapler open so it's at a straight angle. Then look at the picture on the bottom of the stapler. Its' saying to pull out the black click thing and then (here's the tricky part) put the staples into the body of the stapler, not the part you just pulled out. I always have to relearn that. My learning curve is getting slightly better, though.
Apr 26, 2012 | Staples One Touch High Capacity Stapler
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
The stapler is fixing two staples instead of one at a time.what can be the defect and how to correct it?
First check and make sure the proper staples are in the gun. Also check and make sure the stapler is clear and no jammed or broken staples are in the gun. If this is a desk stapler make sure the plate is locked in for the staple to hit and bend the ends out or in. if all this is working the driver or the piece of metal that pushes the staple out may be bent. If the stapler is new take it back if it is not a minor problem and get a new one.
Jul 01, 2010 | Tools & Hardware - Others
Oct 06, 2008 | Stanley Heavy Duty Stapler, Cast Aluminum...
Televison & Video Logo
Top Televison & Video Experts
