Question about Curtis ProScan 7" Capacitive Touch Screen Tablet with Keyboard and Cas
Proscan tablet plt7810k repair how to open case ?
Power button is recessed, how to open tablet case ?
How do I reset my visual land android tablet
In the settings menu you should find a back up and reset option. Or on most android devices with the unit off press and hold the volume up and power buttons. Continue to hold both until it boots to the android menu. Use the volume up and down to scroll and power to select. Select factory data wipe. If yours does not have a volume control then there should be a recessed reset button usually located on the back of the unit. Insert a paper clip and press and hold.
Oct 12, 2016 | Prestige Visual Land 10" Tablet Android...
I got my son this uniden tablet model UTAB71IT HAS NO UP DOWN VOLUME BUTTON so now how I reset it if I can't hold the volume n power button to reset pattern lock on the main screen he can't remember.
Look for a small hole usually in the back and often not labeled. Use a paper clip to press the recessed button in it. This will delete all data on the tablet.
Jul 31, 2016 | Tablets & eReaders
Rca tablet will not power on
First of all, it is recommended to try and charge your tablet for at least 1 hour. Now try to start the tablet and if that does not start, then follow the step given below:
- Use a small, thin object, such as a paperclip, to press the recessed reset button located on the bottom of the tablet.
- If done correctly, the tablet will power off and restart once and you will able to see the screen.
- If tablet still do not charge or start, it is recommended to contact tablet manufacturer for further assistance or repair it.
GuruAid.com
Jul 05, 2016 | Tablets & eReaders
My Samsung galaxy Tab 3. 10.1 will not charge I believe it is the port. What can I buy or repair to fix it and where and we he cost estimate
If tablet still do not charge or start, it is recommended to contact 'Samsung Service Center' for further assistance or repair:
http://www.samsung.com/us/support/contact
GuruAid.com
Jul 01, 2016 | Samsung Galaxy Tab 3 16GB 10.1-Inch White...
How do I open Tablet if I forgot pin #?
Recover Android Device in case of Forgot password/pattern ...
visihow.com/Recover...Forgot.../pattern_unlock_an_Android_device
To perform a Factory Reset, take the following steps: Turn off your Android device. Press and hold the "power", "volume down", and "camera" buttons simultaneously. Release the buttons once your Android device is powered on. Scroll using your "Volume up and down" button until you find the "Factory Data Reset" option.
Nov 29, 2015 | Tablets & eReaders
How can I fix my tablet
First make sure the tablet is charged up. Sometimes you just need to hold the power button down a little longer. If that does not work, most have a reset button that is recessed on the bottom edge of the tablet. You may need to get out the manual for the tablet to find the reset.
Apr 08, 2015 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
I put my pin # on my new pad, now it wont open, how can i get my pad opened again
Factory reset! Press power for about 30seconds so it ends up off! Then press power and volume+ buttons together until reset page appears, select factory reset!
Jan 18, 2015 | Irulu 7" Touch Screen 2gb Android 2.3...
I bought my son a 7 inch zeepad tablet. He has been very happy with it. Unfortunately, his power button has become dislodged and has fallen inside the tablet, making it unable to be played. I need a...
Hi James. The website for ZeePad is www.zeepad.net but unfortunately, there is no contact information there that I've been able to find. There is indeed a link for "Contact Us" but it's not operational.
I've worked on quite a few of these tablets--never the Zeepad specifically, but you are likely to find that by the time you get the replacement power button and find someone to install it, it will be cheaper in the end to replace the tablet. I hope I'm wrong, but many of these imports are just so inexpensively built it's just not cost-effective to repair them.
Sorry.
May 26, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
My EM543 tablet will turn on, the word tablet "Tablet" comes up with a rotating circle underneath it . Cannot open the tablet.
This works with devices having physical home button:-
1. Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory.
With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
NOTE: You'll not only lose the apps on your internal memory and the data associated with it. All the device updates will also be lost and you'll have the version of Android your tablet came with.
Reset Factory from safe mode android, watch video in my blog
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Dec 26, 2012 | Tablets & eReaders
Acer tab A200
You may have to perform a reset if your tablet fails to respond when buttons are pressed or the screen is tapped. To reset your tablet use a small thin object (such as a paperclip) to press the recessed reset button.
Or do Clean Boot to restore the Acer Iconia Tab A501 factory default settings.
  • Open Settings from the application menu, then tap Privacy > Factory data reset.
  • Click Reset tablet and then Erase everything to format your tablet.
Jun 29, 2012 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
Curtis ProScan 7" Capacitive Touch Screen Tablet with Keyboard and Cas Logo
Top Curtis Tablets & eReaders Experts
Michael Harrier
barez
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Curtis Tablet and eReader Expert? Answer questions, earn points and help others
