Scan snap err=ox80210019 - Computers & Internet
Err message with Nikon D70
Is there anything else than the ERR? Hold on I will have to look it up, just a moment.
Oct 07, 2008 | Nikon D70s Digital Camera
After scan Scan Snap S510 fails to display the document and serial number in the Scan Snap organizer. How do I get this to display in the scan snap organizer again?
Here is how you fix it. Sell the scanner and make $200.
Put all your documents into an envelope and have us scan all your document for you!
Go to Shoeboxed.com and check out what we do and then call me, Justin, at our main number and I will set you up with a complimentary 150 free scans of all your receipts, business cards, and other documents all on the house!
Call 888-369-4269 and ask for me!
Jun 25, 2010 | Fujitsu ScanSnap S510
Error message on D80 Nikon
To assist you we need more information than you provided. For the ERR message read page 132 in the D80 manual.
Apr 13, 2010 | Nikon D80 Digital Camera with 18-135mm...
Regency scanner r1070 error message fr err, will not scan
i have same problem with my scanner what my prob was is moisture got into the radio and it sat for while and corosion ate one of the pins of a crystal causing it to have fr err on any channel i put it on replacing the crystal fixed it for me but with scanners anything could be wrong
Jul 18, 2009 | Radio Communications
ERR MESSAGE, NIKON D2X
the only time i have ever seen this message on my D2x is when the lens is not all the way snapped on. try re-seating the lens.
Dec 25, 2008 | Nikon D2X Digital Camera
Lexmark x2500 err msg: UNABLE TO CONNECT
google the error message. Lexmark website is useless and expensive ink cartridges.
If this fails..get an HP or Canon.
Nov 24, 2008 | Lexmark X2500 All-In-One Printer
Regency R1070 scanner Fr Err
if an out of band frequency is put in that channel you will get the Fr Err message as well, just put in a frequency within the scanners specs
Sep 24, 2008 | Radio Communications
Brother MFC-440CN Error 50
The cover on the 440CN is tough to get off. I have removed many. I will tell you that the cable from the scan (black mylar [plastic]) is fragile. I destroyed one of the printers by killing the connector end of the cable. That being said, on the 440 you have to remove the push button panel before the cover. There are 3 screws in the back. The cover then snaps off but feels like you are breaking it and it will snap as it comes off. I did not break this part on any of the printers so.... you should not worry too much. After that there are clips on the front that keep the top cover on. You must release these with a screw driver. You can insert the screw driver and twist. While twisting apply some upward pressure and it will release. You also have to remove a number of connectors, ground wire to get it apart.
Mar 18, 2008 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
