Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool versus electrolux
How long is each machines tastes cycle?
    Top Expert:
  • Whirlpool Master
  • 75,822 Answers
We do not have this information.
Posted on May 17, 2014
How to get it to do self clean and how long is it suppose to take
Electrolux Self-Cleaning Oven ' Electrolux Kitchen Range ...
? 0:47
https://www.youtube.com/watch?v=JNVPSVe_MV0
Mar 25, 2015 - Uploaded by Universal Appliance and Kitchen Center
Electrolux fresh clean feature is the perfect ingredient for cleaneroven, with 3 different levels of cleaning .
Manually Starting Self Clean cycle on Electrolux Washer
ths.gardenweb.com > Home Forums > Laundry Room
Feb 10, 2011 - So, I want to do a self clean cycle manually. ... wake up washer by pressing any button rotate cycle knob to handwash press start and then cancel. ... I am not sure my machine is operating on the clean cycle.
Nov 23, 2015 | Electrolux Vacuums
My Electrolux front load washer over flows even after added new pressure it also indicate no water on display
the solenoid is sticking at least that's what I call it you can turn the water off once its full wash but stayed dead on it so you can turn the water back on for rinse cycle if its a computer operated washing machine get rid of it and buy your older model whirlpool a Roper anything with compatible Parts I found many of my washer is on the side of the road and fix them good luck with yours
Feb 26, 2015 | Electrolux Washing Machines
Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
Aug 03, 2009 | Electrolux Washing Machines
Bad taste in coffee
Run a pot of 1/2 white vinegar and 1/2 water through a cycle. Then run 2 cycles of plain water. Wash pot and basket in the dishwasher.
Jun 12, 2009 | Breville Die Cast 800ESXL Espresso Machine
Solution for "how do you determine if the pump is working versus the water valve needing replaced"
Make sure the water is turned on to the machine.
Set the machine to start the cycle. Put a volt meter on the water valve terminals. At the fill portion of the cycle you will read 120 volts at these terminals. If you read 120 volts and no fill, the water valve is bad. If you do not read 120 volts, the timer is bad.
Fill the tub with water using a pot. Set the machine at the pump out cycle. If it pumps out, the pump is good.
If it does not pump out it could be a bad pump or bad timer.
May 26, 2009 | Whirlpool 24 in. DU900PCD Built-in...
Coffee tastes very acidic
Hi kdimof,
I realize you posted this problem over a year ago, but I was curious to see if you were ever able to resolve this problem, or find the exact cause.
I have the same issue you describe. I descaled my Lattissima for the first time using the Nespresso descaling solution. And now, two months later, I cannot remove the chemical smell/taste of the descaling solution. I've run numerous descaling cycles with just water (as per Nespresso's customer service advice), with no success. I was forced to accept a refurbished machine (even though my Lattissima was only 3 months old). The refurbished machine is currently on the way. We'll see if I have the same issue when I descale this one.
Thanks, Redfran
May 14, 2009 | Nespresso Lattissima 660.R
Suddenly coffee tastes TERRIBLE!!!
First try putting a cycle through with no coffee - see if you have any more luck identifying the taste. If you haven't descaled recently, that could be the cause - scale can hold other materials which can be tasted - run a cycle with 50% white vinegar, then rinse through a couple of times and see what you get - if you need to get rid of any vinegar taste, just run a cycle with a couple of teaspoons of bicarbonate of soda through. The water could still be to blame - even purified, there are certain things that can change that most purifying methods will not remove, such as higher salt levels during summer months etc. Make a cup of coffee without the machine at all, and see if you get the same aftertaste. The machine may not be to blame. Hope this helps, please ask again if you need more info :)
Sep 09, 2007 | Cuisinart DGB-600 Coffee Maker
Whirlpool Duet GHW9150P Front Load Washer Logo
14 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
