Question about Dell Inspiron 9400 Notebook
Dell inspiron 9400, the display has horizontal lines and "scrambles" text and pictures, duplicates text etc, the laptop runs normally.
  • johnfindl543 Jun 23, 2009
    I did a diagnostics test for the video card fan and got the error message:
    Error code 3700:011B
    Expected video fan low RPM of 2500
    Detected fan RPM = 3512
    Does this mean I need to replace the video card fan or the entire video card?
    Thanks john
    After completing the diagnostics the display is now back to its normal condition, do you still think I should replace the fan?
    President:
  • 987 Answers
This is the memory problem //try to change the RAM...
Posted on Jun 24, 2009
    Brigadier General:
  • 3,917 Answers
From the symptoms and a breif discussion with Dell technical support its clear that there is an issue with the Video card and the fan located on it.
Run the Dell diagnostics to verify the operation of the fans. If the video card fan is not running, DO NOT use the system - you'll turn a $50 fan replacement into the need to replace a $400 video card.
If this card has been in your system for a while, not a new install, then your GPU is going bad. You might try updating drivers for the GPU and testing the memory, but it looks like a bad GPU chip.
No changes to your monitor? No chance the monitor cable from the unit is loose, checked the connections on both ends?
Run the Dell Diagnostics for hardware, on F12 Boot Sequence, drop down to Diagnostics, you can check the memtest, prepost, etc, but you need to drop down and do a hardware test or a system tree test.
Please follow the link bellow to understand how to replace the graphics card.
http://www.insidemylaptop.com/upgrading-dell-inspiron-e1705-9400-graphics-card-memory/
Thanks for contacting Fixya
Posted on Jun 23, 2009
Charging light is flashing
There are two possible causes for this issue:
1) Your dell 9400 charger is malfunction
2) Your laptop dc power jack is loose or dead
Possible troubleshooting step:
1) Borrow a compatible dell charger to plug in your laptop, if it works without any issue, it means your dell inspiron 9400 adapter need to be replaced.
2) If the compatible dell 9400 charger won't work normally, the problem may lie in your dc power jack.
Hope this will help.
Jan 07, 2013 | Dell Inspiron 9400 Notebook
I have a Dell Studio XPS PC. Recently, my PC monitor screen began to show all sorts of square spots and vertical lines and horizontal lines with a distoration of color and graphics. Now the Windows 7 will...
try starting it in safe mode....you do that by pressing the F5 key before windows starts up.. like right after you turn it on...once your in safe mode do a real good virus scan..i have seen that happen and it was a virus
Aug 15, 2012 | Dell Inspiron 9400 Notebook
Bios Password dell inspiron 9400
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-9400-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
May 14, 2010 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 laptop display problem
First power the system on using Fn+Power and see if the diags run and you have video. If you have video in the diagnostics, then I'd suspect the video card as the failure point.
Also connect an external monitor and press Fn + F8 to activate the VGA port If you get video on an external monitor, I'd suspect the LCD as the failure point.
Dec 26, 2009 | Dell Inspiron 9400 Notebook
Running with AC power, my Dell Inspiron 9400 would randomly show the Blue screen. After a few times of rebooting, I could see the Windows logo with horizontal white lines about 1 " long. Eventually the...
it was a brilliant laptop ever manufactured. check the costing. for the new laptop as well as the warranty pricing. Yes it is worth repairing, if you can manage the cost. becasue extending warranties would be a cheaper option. The LCD needs to be repalced in your case.
Oct 02, 2009 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 notebook display blank
Most likely, as you have said, this is already a hardware issue. For hardware issues the best thing to do is to have your system checked out by a local hardware technician. If your video is in fact the issue here then most likely you will be needing replacement for the motherboard now this costs a lot. so you have two choices really, 1) Just get a new laptop because the price of a new one will cost almost as much as replacing the part. 2) Have it fixed by Dell and have the part replaced then ask for warranty reinstatement, if they have one.
Jun 06, 2009 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 display goes blank after a few minutes
If the issue occurs in the safe mode, then I'm suspecting a failure of the LCD backlight. (It warms up and quits) Also see if video stays on using an external monitor. If it does, then the LCD is most likely failing.
If video goes out on an external monitor as well, then the Video card is failing due to overheating. Make sure all vents are free of dust (Clean with canned compressed air) and the all fans are functional (Run the fan test in diagnostics) If fans check up, then video card is failure point. If fans fail diags, replace affected fan 1st
May 21, 2009 | Dell Inspiron 9400 Notebook
you may have damaged the screen in which case theres not much more you can do then replace it.if its a new labtop it may be still under warrenty in which case get back to dell.
Mar 22, 2009 | Dell Inspiron 9400 Notebook
Flashing block patterns and zigzag lines on lcd display
Common problem.
There are small VRAM BGA chips.
1 or 2 of them needs REFLOW.
Basically needs board service.
Mar 13, 2009 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 PC Notebook replace hard drive
On the underneath side of the notebook there should be two screws that are usually labeled with a picture of a drum. Remove tham and the drive should slide out. Remove the drive from the tray you slid out and reverse procedure to re-install.
Jan 31, 2008 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 Notebook Logo
60 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
