Question about ASUS Intel 850 Chipset P4T-E (P4T-E/WOA) Motherboard
ASUS p4 T.E
Iamnaruto1@yahoo.com
my pc is a ASUS p4 T.E it turns on but i get nothing on screen
i tryed all my video cards and nothing comes on screen any solutins on what what i am suppose to do. is there a way to reset my motherbord or something like that?
any help is greatly appreciated TX.
danny
    Novelist:
  • 127 Answers
If you get absolutely no video during post then yup, try a different monitor, a different (known working) video car, and then a different slot on your motherboard.. more likely the monitor or video card than the slot though..
oh yea i just posted the manual so thats available for you now if you don't have yours any longer..
and drivers are still available for it thru asus.
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
    Problem Solver:
  • 16 Answers
Have you tried a different monitor? A different slot on your motherboard for the video driver? If you look at the motherboard manual, you will find a jumper that will reset your CMOS. However ,I doubtful this will solve it. Do you get a beep at first when you power on the computer?
Posted on Jun 24, 2009
I want to install an Ati Radeon Pro 9800 vga card in my Asus Terminator P4 533a, but the card is not recognized. I tried to change the vga bios to agp and pci, no effect. I even disabled onboard vga, then...
Hi,Try to clean your video card by using an eraser,then plug it again,If the problem still exist,try to use other video card,but still not working the problem would be your motherboard.thanks
Sep 02, 2011 | ASUS Terminator P4 PC Desktop
Hello I have a ASUS Eee PC 1005. How do you know if your video card is blown? I have some knowledge of computers but not this brand. I turn it on and 2 blue lights come on (the light bulb and wifi) but...
This is more likely to be the Inverter which provides the power to illuminate the screen. I have just had to replace mine in a Toshiba laptop. Having said that, mine would power another monitor. The cost is about $90.The video card is usually part of the motherboard. The website tells you everything apart from the video! http://usa.asus.com/product.aspx?P_ID=BtksJTDENqfsnuyf
If you have two computers with the same problem, I would contact Asus for warranty repair, as having two fail is too much of a coincidence.
Apr 11, 2011 | ASUS Eee 4G Notebook
ASUS P4-533 won't power up.
Please disconnect all the connectors and put them one by one and try following DYI
1.Refix the connectors and the check the power is coming.
2.If the power is coming in the machine and the fans are moving then the issue is with the RAM refixing open the cabinet and then refix the RAM module and it will work.
Feb 19, 2009 | ASUS P4-533 Terminator (terminator p4)...
My Moniter Is Blank
First make sure that you have the P4 connector (the square one at the top of the board connected to your P4 power from the power supply.
From here I would disconnect the data cables from the hdd, optical drives, and remove all video/peripheral cards. You should have only the RAM, CPU, and power connected, then try to boot again.
If this works, then add 1 device at a time until it fails to start. This will isolate the component that is giving you problems.
With a single stick of RAM, try to get the computer to POST. (if possible, test the ram in another machine first to ensure that RAM is good)
Jan 01, 2009 | ASUS EN8400GS SILENT/HTP/256M PCI-E TV-OUT...
ASUS P450-VX -How to diasable on board video
The onboard video should be disabled in bios.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
Dec 11, 2008 | ASUS Terminator P4 PC Desktop
Only turns on but does not boot
check for the cmos battery!! see if it still on 3 volts
Feb 28, 2008 | ASUS P4VP-MX Motherboard
P4 comp not booting up
get working processor like that of your son's system and working ram, remove both the processor and ram on the system and substitute with the new ones and try booting.
Uzowuanya
e-mail:uzowuanya@yahoo.ca
Feb 14, 2008 | ASUS P4B266 Motherboard
Motherboard detects nothing
anniegms, I had the same problem with a new Asus board running a Dual Core Duo Quad processor. The boards BIOS was not updated to handle the Dual Core Duo yet. I had to switch processors to a P4. Use a different PC to make a BIOS update disk. Update the BIOS and switch processors back. But I had all the same symptoms of yours. However I did/do have a PCI-E XFX Fatality (Nvida) based graphics card. I would check or swap processors, it sounds like the board is waking up but not the processor. Just my thoughts.... PCdok
Oct 21, 2007 | ASUS P5GD1-VM Motherboard
Video driver no working after rebuild
I am assuming this happens when you are trying to go in to windows? Have you tried safe mode? hit the F8 key before you get to windows then choose safe mode. If you can get in go to device manager and take off all video display adapters and then try to reboot normal. If you get in then you can apply the drivers for your card or integrated video.
Sep 27, 2007 | ASUS P4-533 Terminator (terminator p4)...
ASUS Intel 850 Chipset P4T-E (P4T-E/WOA) Motherboard Logo
219 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
