Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Troy built ltx1842 wll not go forward or backward
Troy built 42in cut wont move forward or reverse . smells like rubber burning , could the belt be slipping ?
If you smell rubber... replace the belt and make sure ALL pullies are turning free.
Jul 01, 2017 | Troy Garden
Troy bilt mower 42 " rear end noise..forward and revers..very loud.????
Sorry to tell you but either the Gearbox or the rear Axle is broken. This may well be the time to think of buying a new replacement Mower, It is worth asking if they will give you any Discount on your present mower. If you do not ask they will not give you anything. Best Wishes, Malcolm.
Jul 03, 2015 | Troy Garden
Drive system not working
I'm not sure what you are expressing. Give us a call when you can be at the washer so we can diagnose it over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Dec 15, 2013 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy built lawn mower (riding) won't go full
I did not know riding mower had a gas pedal. I know if you leave the throttle control up all the way the engine will choke out. The pedal you are pushing, I think, is the forward/reverse hydrostatic transmission. You may need a new drive belt. The one you have now may be stretched out.
Good Day.
Oct 07, 2009 | Troy Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
18 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
